1 - 6 of 6 Posts
Anyone know if the tail light plugs are the same on the pro as the xp 1000's?
Thanks
I ordered a 3ft pair of Amazon color changing whips. Will my pro have any issues powering them or will I cause pro if I just piggyback them off the tailights?
The book says the tail lights and head lights are on a 10 amp fuse. If you have an amp meter you can measure accross the fuse location and see how much they're actually using when powered on. Check the whips to see their current draw. Add all together to see if your under 10 amps.
I run my double whips this way, never had any issues 8n 1k miles. I did have to open up the circular mount point holes but no issues whatsoever
1 - 6 of 6 Posts
