Here are some pictures of my RZR after I installed the Legand Air Suspension. I don't have to worry about hitting high center now. Sorry about the movie, have not figured out how to do it. Maybe I havn't figured this out either.
The way it works is the two front shocks are on one switch and the two rear shocks are on one switch. You can raise the front end or the back end to a height or ride you want. Jared from Mt. Pleasent, Utah explained the RZR will not charge the battery until it reaches 3000 RPM. So as you raise it up you have to make sure it is charging or you have a strong battery. The picture in the vivatar is pre air suspension. It has a 3" ROK TEK lift kit.
