1 - 4 of 4 Posts
Got the Muzzy exhaust installed today on our new 2011 RZR4 and started the PCV/Autotune installation which I thought was going to be simple. Well, one set of the injector wiring connectors hooked up fine but the other was slightly different and the TPS connector was totally different.
Did Polaris change the harness on the 11's or did I recieve the wrong PCV:rollfinger:
I also posted this in the RZR4 specific section, please delete one of them if that is against the rules
well if it makes you feel better i just installed one (pcv/wb2) on my 2010 and it reads double rpm and ill be damned if i know why.
it looks like it'll be great once its working however.
Discussion Starter · #4 ·
The fuel injection system is totally different on an 11 rzr. I don't think there is a pcv yet for the the 11s.
Yea, I knew about the changes to the fuel and ignition alternating which is why I made sure the vendor understood this was for an 11. I thought he verified but now I think not. Now I am concerned if the Muzzy will make me too lean with the stock controller.:sad:
1 - 4 of 4 Posts
