PCV and autotune with boost
41K views 78 replies 22 participants last post by  Lottie
I have a boondocker turbo kit on my 800. it has a garrett gt15 turbo, ait to air intercooler, and a third injector in the intercooler. it has a fuel programmer that is pretty cool and does a lot of things but does not autotune.
when I go to the mountains I raise altitude by 5000' or more. it runs like crap and I would have to re tune the damn thing every time I head up.
my question is what all do I need in addition to the PCV and autotune that I already have to set it up to run my turbo setup?
I know I will have to delete the 3rd injector and add larger injectors to replace the stock ones. what injectors do you recommend? I will run 12psi and below
what electronics do I need to add to the PCV?
will it autotune as well with turbo as it did without?
Bring up the PCV software on your computer and under the Help tab is the manual. Read it -- Several times. It's not the best source referrence -- Better to have been written in flow chart format to begin to understand how the PCV functions with Boost.
Another referrence is from their web site -- Watch all the instructional video's. There are many mistakes in a couple I watched - But one gleens a bit of information.
Use your PCV and Autotune. There is no difference between it and the PTi version except yours doesn't have a MAP sensor. ALL methods of tuning are the same between the 2 units - So no need to buy the PTi version.
Tuning -- I now recommend instead of tuning via TPS with a Pressure referrence (This is Enabled when you build your voltage table and place a check in the enable box.) -- To tune via Pressure only. No matter how bad you screw up the Fuel (Pressure) table -- Autotune will re-build over time.
Injectors -- For a cheep set you may wish to choose a pair of 72' from an LS2. For a matched set you may wish to select a set of ID72's.
I can't stress enough -- Read the manual ..... Several times. Work with the software to begin your understanding of how this fuel system operates. There is no better piggyback fuel system period -- But it does take a commitment to fully understand and how to properly configure.
Elevation change -- Not an issue IF the various tables are built correctly and take into account one may change elevation. The only exception to this statement is -- As one rises in elevation atmospheric air pressure decreases and one may want to increase Boost to compensate. No adjustment of the fuel system is necessary.
Good Luck -- :)
:ride:
I suggest this not be done for several reasons - For a Boosted application .. Far to many variables and you won't have the understanding to make corrections.
Just my opinion on this -- Take my recommendation for what it's worth.
Good Luck .. .. :)
:ride:
Yes, do what Sparky says haha! He is of great help with the PCV!
Yeah I was hoping sparky would see this thread.
I have ran the PCV on n/a motor but not turbo.
When I bought the PCV the previous owner gave me a map sensor he had that he was gonna use with it for a turbo. Or at least that's what he told me.
I will read up again on the manual and play around with the software more and see if I can get a better grasp on using it with the turbo.
Thanks guys for always helping
I'm in the Shop today working on an issue with mine ........ Later this afternoon I'll put some thoughts together and make a post that should be of great HELP .. :rofl3:
Thanks by the way for the Words .. .. Although I'd prefer those thoughts to be expressed as .. .. Evaluate what I might say and evaluate for yourself. Because - With the PCV -- --
There are 3 methods of Tuning and within each method there are an infiniate number of variations -- Which begs this question .. ..
The method of Tuning used -- Is the motor running within the Targeted A/F value established in the Target A/F table -- This can only be validated by Data Logging -- If the answer is Yes .. Then your Golden with your method of Tuning -- And .. It most likely will be different than the way I have mine setup - And I'm happy to disclose.
This isn't the best way to put this but at the moment I'm busy !!
Break Time Over .... Later .. :)
:ride:
hahaha!!!!
thanks sparky we really appreciate the help and knowledge you bring to us!!!
No rush on anything here man share at your own convenience! I enjoy learning everything I can about these machines
#15 ·
Ok .. Onto the PCV
In general terms -- As you all are at different stages - Elevations an so on .....
You've installed a PCV on your N/A engine and presumably are running one of the canned fuel maps. Now you want to add an item to the motor and install the Autotune. So far so good.
Now -- What method of tuning will you select ?? Under Autotune Style you have 2 choices -- TPS or Pressure. For most -- The easiest method of tuning is TPS. And looking at the choices one then thinks -- Gee ....... I can't select both for when I go to a Turbo. Actually you can select both -- Just not at this point in the program. Dynojet does have some quirks on the programming -- One just has to have an open mind and experiment and learn and understand the big picture.
Add Boost to the equasion - With the PCV/Autotune. You will need a MAP sensor. Select the PCV PTi version and it comes with the MAP. I suggest for the MAP sensor -- Go with the GM universal 3 BAR MAP with the short pigtail and wiring guide.
Wiring the MAP -- It must be powered by a regulated 5VDC source. Yea -- Great ... Where do I find one ?? Well -- There is no spare sources on the ECM or on the PCV. NO issue if using the PCV PTi as it has a regulated source within. For those with the older PCV - You got to come up with your own source. Couple of devices on the machine that require 5VDC -- The TPS and the TBAP sensor. Personally -- I tap into the TBAP.
The output of the MAP simply wires into the PCV - No issue here.
Let me comment on Timing -- On the 800's ...... Polaris warrantees the CVT belt for life. I'm not interested in discussing this point but you will be interested in this point. To hedge their bet that they would have to warrantee a blown belt -- Polaris did something that most don't know and maybe don't understand. They de-tune the engine so it doesn't build HP during clutch shift out. I've commented on this over the past several years and made many posts on this. Search for the information and how to correct if you've an interest. Run the PCV PTi and you can make the appropriate timing adjustments within. Run an older style of PCV and you will have to run a Programmable Ignition Box.
One can run any type of fuel one wants -- Even dual fuel setups. Want to run more than 2 injectors or more than 1 bank of injectors -- It is possible but beyond what I'm willing to post.
Injectors -- Stock for the 800 ........ 2 injectors at a flow rate of 18.25 lb/hr. One can overdrive these under Boost -- UP to about 6 PSI and maintain a relatively safe A/F ratio.
I suggest running just 2 injectors -- Just larger. Personally I'm on my 5th set -- I used to have John at Injector Dynamics build them for me -- During this early time and long before I went to the PCV -- I experimented with several other fuel boxes and well -- Had a miserable time tuning.
Enter the PCV -- Now one can select fireplugs and still have complete control and engine idle. I suggest 72lb/hr injectors. Either the USCAR style from the LS2 -- Cheep but only matched within 6% of each other or go straight to the head of the class and go with a set from Injector Dynamics -- Their 72's.
Programming the PCV - Method. Up until this Summer -- I've tuned via TPS with a Pressure referrence and helped many along the way to do the same. It takes a good understanding how to properly program and a good understanding of what's happening to make it work correctly.
With Boost and tuning via TPS with a Pressure referrence -- Autotune builds the Fuel map. This map starts off with all zero's populated. After excepting the Autotune Trims -- The Fuel map is built. You have no need to ever touch this map.
Run bigger injectors -- Now one must manually correct the injector pulse for these larger flowing injectors. This is done via the Fuel (Pressure) table. Populate all cells. Which brings up another point --
Dynojet recommends that the Autotune not be enabled during engine idle. 2 points to be made here. When the manual was written -- It was for the old PCV (Nothing wrong with it as I run one) -- And this comment was directed at the motorcycle engine. Specifically the Harley and tuned pipes. 2nd point -- No thought for Forced Induction.
I suggest that the Autotune be enabled in all tuning cells.
AS I think about all this -- There is so much I could write about but just don't the desire to write a book so let me get to my final Tuning points.
For absolute ease of Tuning and something you will know nothing about -- I suggest one Tunes via Pressure only and tune via Kilopascal. Yea -- I know .... What the Hell is that ??
Let me make this real simple and not go into the theory of Atmospheric Pressure and the US Stand of Measurement of PSI or the Metric form of Pressure Measurement -- Kilopascal or KPa or define Absoluite Pressure.
As I said -- I'll make this real simple .... Here is a chart that has all the information you will need - And a 2nd supporting chart for referrence only --
Ok -- Trying to keep this on track and short and simple -- Onto the Voltage table. One can select 1 - 10 colums. Select only 2. Don't worry -- The software scales perfectly between the range you have entered. By the way -- This table is for the MAP sensor as the PCV has no way to distinguish or register Boost - But a voltage it understands and can compute.
If your tuning via TPS You can Tune with a Pressure referrence either in the US Standard of PSI or the Metric Standard of KPa. If by PSI then for the 1st colum: 0 PSI = 1.592 and the 2nd colum: 25 PSI = 4.37 -- Hit OK and your done with this table.
Tune via Pressure only and I suggest populating the Voltage table this way:
Voltage 0.75 = 48 kpa and the 2nd colum: Voltage 4.75 = 300 KPa. Click OK and your done with this table.
The Fuel (Pressure) table. Build it exactly as I've sketched in the 1st picture in this post. This chart takes into consideration engine intake operating in a vacuum and also under Boost up to and including 21 PSI. If you want to run more Boost -- I've included the formula's at the top of the chart.
On the Fuel (Pressure) chart -- Select 26 colums. The 1st 4 - are for engine vacuum - The 5th is for engine at atmospheric pressure and the remaining 21 colums are for Boost - At 1 PSI referrence.
On entering the KPa values to the 26 colums -- An easy way to do this is enter only values for the 1st colum and the last colum and hit the Interpolate button. The software builds all intermediate colums automatically. SWEET -- We got this far !!
Now-- Tuning this way -- This point on the Autotune. It no longer builds a Fuel table - When one excepts the trims. It Re-Builds the Fuel (Pressure) table that you have manually built. I'll try and remember to talk about how to build .. ..
So -- No matter how bad you screw up building the Fuel (Pressure) table -- Autotune corrects it. Tune via TPS and screw up the Fuel (Pressure) table and your going to have one strange looking Fuel table.
One comment on the Autotune -- It does not correct the injector pulse in real time. And -- Not in the next Power Stroke Cycle -- Or the next. And so on -- It may take several hundred engine revolutions for the Autotune to make an injector pulse correction -- In it's Trim table. This is one reason one has to except the Trims and Send Map back to the PCV. Turn on Cell Tracker and although it now displays the current tuning cell that is active -- No value is displayed.
A/F table -- Populate every tuning cell with a value that your comfortable with. Generally speaking -- As the load on the engine increases (Boost) -- The lower the A/F ratio. I tend to run a bit leaner than most -- I also blend a bit of oil in my fuel to help with detonation.
Ok -- Last tidbit as It's Beer Time and we're goin out for Dinner -- Yea !!
Building the Fuel (Pressure) table. As stated -- This table must be fully populated manually in the beginning. Yea -- Great ........ HOW ??
1st -- Identify the size injector your using. The motor particulars are not relivent.
Run a set of 72's -- This is 400% larger than stock. Don't populate the table and try starting the engine. It will start and if one pumps the throttle to keep it running -- For grins look at your dash Boost gauge. Blip the throttle and you to can Boost over 10 PSI !! Don't do this as this rich fuel mixture washes down the cylinder walls.
Now -- Lets look at what's happening with these injectors. One needs to trim the injector pulse so the engine will idle at the target A/F value in the Target AFR (Pressure) table. What your doing is helping the Autotune out here. For the 1st 5 colums enter a value of -60. This is just a starting point so you can start the engine and look at the software screen and see what the A/F ratio is. Simply change this value in all 5 colums and watch the displayed A/F change. Get it close to the value in the Target A/F table and your Golden. Now for the remaining 21 colums that represent Boost. On a scale of -3 .. And from the value that you ended up with in the 1st 5 colums -- Simply deduct 3%. As in the example .. -60 in the 1st 5 colums ......... The 6th colum then would be -57 and so on for the remaining colums.
As you except the Autotune trims -- This table is re-built .. .. SWEET !!
Now -- In closing ........ These are only my suggestions. You may wish to change your method of tuning and in the end have the engine operate within the specified A/F range also. There is no one correct way to Tune. Just some ways are better than others. And on that note --
Short Story ...... I've even seen one fellow tune his Boosted engine without a MAP sensor. I's possible but extremly difficult to build the tables this way.
I'm just a retired OLD Man who has a Shop and an Old Classic RzR with a couple of Built Motors and 2 complete Turbo Systems - And Like to tinker .. As there are so few Pleasures left in Life anymore .. .. :rofl3:
Speaking of Pleasures .. .. Beer Time -- Then Dinner OUT -- SWEET .. :rofl3:
From this point on -- One should be in good shape to take over and enjoy your Boost .. :)
:ride:
WOW!!
Sparky you are the man sir!!! thank you so much for sharing and taking so much time to do this detailed writeup!!!
I really enjoy working on and learning about these machines. bost is new to my world so all this information is very valuable.
Thank you again!!!!!
now I have to read your post 9 more times and play with my PCV software for hours hahaha!!!
Thanks for the Words .. Re-reading i see that I've left out a great deal but there is enough there to get on started on the right track.
On the question of building the Fuel (Pressure) Table ........ The -3 value is the percentage of injector pulse trim - As it relates to each successive colum. This is an arbutrary value. One can use -4 or even -5. This is the percentage of injector pulse trim between colums and remember in my chart I have each colum representing 1 PSI differential between each colum.
If one ends up with the 5th colum's value being -60 (60% reduction of the injector pulse) -- The next colum then will be -57 (57% reduction of the injector pulse) and so on to build the table.
As Boost rises -- more fuel is required to attain the desired target A/F ratio.
Also -- As time goes on and one looks at the re-built Fuel (Pressure) Table -- As the Autotune rebuilds it ........... One will notice wild swings in adjoining tuning cells. Not to worry as this is a clear illustration of a poor fuel map within the Polaris ECM. Remember - The PCV is a piggyback fuel box and only takes what the ECM gives it to work with.
Also on this point -- There are several canned fuel maps with in the ECM. So -- The Autotune is always working on correcting the injector pulse. My recommendation is to never disable or disconnect the Autotune. Also I recommend to not be tempted to run a Map Switch. Autotune is disabled in the 2nd position.
Also another point that is very important -- Setting the TPS in 2 locations. Once one has the engine idling and the A/F correctly set by adjusting the value in the Fuel (Pressure) Table -- Now one has to check and if necessary adjust the TPS on the throttlebody. Idle may also be adjusted and if so -- The TPS must be re-set. As an example -- I have my idle set to 950 RPM. I re-adjust the TPS just shy of tip-in which activates another fuel map in the ecm. Then I re-check engine idle and may have to slightly re-adjust and back to the TPS for the same reason. Once this process is complete -- Then one must set the TPS in the PCV software. Very important to do this and is a very easy procedure.
Also on the percentage of injector pulse trim -- Dynojet recommends to not exceed 20%. One can go a bit higher if one wishes. I have mine set to 25%. One can go all the way to 100% -- But the computing power of the PCV is not very robust and the processor is a bit slow and it gets confused and one ends up with a very inaccurate Trim Table. But -- 25% is working for me.
I do feel though that the best method of Tuning is via TPS and Pressure both. To wirte up the tuning method is very involved but one may wish to experiment on this method. Be prepared for some Grey Hairs though !!
Tuning via Pressure though is quick and easy following my chart and works quite well.
If one wishes to Data log and see exactly what and how the PCV with the Autotune is working -- Buy the LCD-200 and a 1G memory card and option the display for 10 times a second display. You will be able to see all 14 data points. It's interesting to see Boost in relation to A/F and how quick a correction is made. Also it's interesting to see how much one overboosts and watch when the blowoff valve opens. So much information for one to evaluate !!
Good Luck .. .. :)
:ride:
#76 ·
I would like to know more about this please.
Couple questions:
1) How or where do you adjust for timing?
2) What is recommended for boosted applicaitons (advance vs retard)?
Thanks I understand now. But for some reason the machine still won't idle with bigger injectors (60psi ) when I try the tune the idle with the fuel. Pressure table But If I put -60 in the 2% column in the base fuel table it idles great I guess I better read the manual again lol.
#20 ·
Lets evaluate this .........
Bigger Injectors -- Whats the lb/hr rating or the cc rating ??
60 PSI -- This is your rail pressure ?? Industry standard for injector flow rating is 43.5 PSI. A static pressure of 60 PSI is fine especially with larger injectors.
And your method of tuning is -- TPS with a Pressure referrence I assume ??
If so -- Your Fuel (Pressure) table will start with the 1st colum representing 0 PSI of Boost. The 1st colum MUST start at this referrence point. I suggest all colums represent 1 PSI increments. Run 10 psi of Boost and taking into account overboosting -- I use a value of 3 ....... This then sets the amount of colums in this table to 14 colums. 1st colum represents 0 PSI or atmospheric pressure -- The next 10 colums represent Boost in 1 PSI increments and the last 3 colums are for over Boosting 3 PSI past your wastegate setting.
One can build out the table to a maximum of 51 colums -- The more colums the more difficult to see in the software.
Now -- You state that you populate in the Fuel (Pressure) table a value of -60 and your idle doesn't change. Your not looking to adjust the idle by doing this exercise. Your setting your A/F ratio.
The table starts off with all zero's in every tuning cell. Start off by highlighting the entire 1st colum. This represents 0 PSI or atmospheric pressure. If your running 72 lb/hr injectors then enter a value of -60 in the entire 1st colum and start the engine and let it idle. Observe the A/F ratio on the software screen and make adjustments as necessary in the 1st colum to achieve the desired A/F ratio.
From this point now one can populate all other colums -- Do so in 3 to 5% increments.
You made a tuning cell adjustment (-60) in the 2% colum of the Fuel table. I suggest never altering this table. This table is completely built by the Autotune. To correct the injector pusle manually do so only by the Fuel (Pressure) table only.
This tells me you may have several issues with the construction of the voltage table -- The Fuel (Pressure) table and you've not set the TPS in software correctly. This MUST be done and is a snap to do.
:ride:
#22 ·
The voltage correlates to the pressure seen by the MAP sensor. The PCV sees voltages from the sensor, so you need to translate those values into a pressure reference for the PCV.
Your table would need to be setup based off the sensor you're using. If you use the sensor Sparky mentions, you should be able to copy his work, otherwise you need to find the specs of the sensor you're using and create your own table.
#24 ·
"Tune via Pressure only and I suggest populating the Voltage table this way:
"The Fuel (Pressure) table. Build it exactly as I've sketched in the 1st picture in this post. This chart takes into consideration engine intake operating in a vacuum and also under Boost up to and including 21 PSI. If you want to run more Boost -- I've included the formula's at the top of the chart.
On entering the KPa values to the 26 colums -- An easy way to do this is enter only values for the 1st colum and the last colum and hit the Interpolate button. The software builds all intermediate colums automatically. SWEET -- We got this far !!"
Ok that probably when I always think wrongly, for some kind of reason I thought when building the pressure chart the first and last value must match the numbers I enter in the voltage table. But actually they will be different 72.3850 and 244.7639 KPa according to your set up, to match the pressure you want to work with.
But on the end your pressure table under PCV map will show the the pressure in KPa or Psi of boost ? Sorry, if stupid question, with my English I mostly think little differently when reading something, specially things I have very limited knowledge of it. :)
Milos
#25 ·
Sorry for the confusion Milos -- Yes .. Something this technical is most difficult to get across on a Forum. I much prefer a 2 way conversation so I can evaluate and taylor my answers as the conversation develops. Anyway ......
I see your point of confusion -- You are correct. Build the voltage table and it has no need to match the Fuel (Pressure) table.
I usually build the voltage table for full range of the MAP sensor. Reason -- Only 2 colums are needed and once built I never have to look at again. In contrast -- --
Build the Fuel (Pressure) table for 3 PSI below engine running in a vacuum and 3 PSI above wastegate set point. Reason I don't build a complete full range table -- Easy ........ Build it using all 51 colums and I can't see it on the software screen. OLD Age = Piss Poor Eyesight .. .. :)
Here's a couple more charts that may be of some interest .. ..
Now you know everything I know Milos -- -- Well ... I may have saved a little something for myself .......... :rofl3:
:ride:
#26 ·
Very informative thread. Thanks all.
#30 ·
On a big picture basis it wouldn't matter as it's just a reference that correlates an input voltage signal from the MAP to an output voltage setting for the Injectors.
One of the keys to Sparky's approach is the baseline method and setup that he's able to get a reproducible result from.
The main point being that he sets his lower boundary (it's idles great there every time) and his upper boundary (think safety here) and then it's just a matter of filling in the blanks from there and he lets the program do the hard work like it's designed to do.
(We do something very similar with a product that we've developed in another industry)
Shhhh... don't tell anyone....
Brilliantly Simplistic
#31 ·
Hey sparky I had a question on building the initial fuel table. I have my pressure voltage/table/axis setup how you described; setting my idle then adding 3# of injector pulse for every lb of boost. The TPS fuel table is set with all zero's and autotune on TPS.
How long do I need to build the fuel table and drive with this setup before switching the AT to pressure?
Thanks for everything, I have a KT kit for my XP and just switched to the PCV PTi after having trouble with the dobeck. Its already running better thanks to your write ups.
Daniel
