1 - 20 of 31 Posts
  1. UTV INC SECONDARY CLUTCH SPRING COMPRESSOR / COMPRESSION TOOL
  2. $59.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
<LI class="item odd">
  1. UTV INC SINGLE ROW LED LIGHT BAR BACK LIT LED SWITCH
  2. $17.95
  3. Add to Cart
  4. UTV INC IS EXCITED TO RELEASE OUR NEW LED BACK LIT SWITCH LINE. THESE ARE AVAILABLE IN RED OR BLUE LEDS AND FEATURE A BACK LIT PANEL THAT ILLUMINATES WHEN THE SWITCH IS TURNED ON. WE HAVE A FEW DIFFERENT STYLES AVAILABLE. THESE WILL FIT ANY OF OUR DASH PLATES THAT WE MANUFACTURE. PLEASE CHOOSE YOUR LED COLOR BELOW. Learn More
  1. Add to Wishlist
<LI class="item even">
  1. UTV INC STEEL FAB CLAMP
  2. $34.95
  3. Add to Cart
  4. UTV INCS MOST POPULAR FABRICATION PRODUCT. STEEL 6 BOLT TUBE CLAMP FOR A VARIETY OF SIZES. PLEASE CHOOSE YOUR CLAMP SIZE BELOW. Learn More
  1. Add to Wishlist
  1. UTV INC STYLE DOOR LATCH RETRO FIT FOR PRO ARMOR DOORS (NOT 4 SEATER)
  2. $99.95
  3. Add to Cart
  4. DO YOU HAVE A SET OF PRO ARMOR DOORS AND THEY KEEP POPPING OPEN? OTHER GUYS IN YOUR GROUP WITH UTV INC DOORS AND YOU WISH YOU COULD HAVE THAT SAME LATCHING STYLE DOOR BUT WITH YOUR PRO ARMOR DOORS? WELL.. NOW YOU CAN!! THIS KIT INCLUDES ALL THE COMPONENTS TO CONVERT YOUR PRO ARMOR DOOR LATCH TO THE NEW UTV INC SLAM LATCH. EASY OPEN, EASY CLOSE, ONE FINGER OPERATION. KIT INCLUDES: DRIVER & PASSENGER BRACKET (POWDER COATED BLACK), CNC MACHINED BILLET ALUMINUM HANNDLES (DRIVER & PASSENGER), CNC MACHINED STRIKER FOR THE LATCH. EASY INSTALLATION AND A LIFETIME OF DOORS NEVER POPPING OPEN AGAIN! Learn More
  1. Add to Wishlist
  1. UTV INC UHMW POLARIS RZR XP FRONT A ARM GUARDS
  2. $124.95
  3. Add to Cart
  4. UTV INC UHMW POLARIS RZR XP FRONT A ARM GUARDS Learn More
  1. Add to Wishlist
  1. UTV INC UNIVERSAL 1¾" CLAMP ON 32" LED LIGHT BAR MOUNT
  2. $249.95
  3. Add to Cart
  4. UNIVERSAL LED LIGHT BAR MOUNT FOR A 32" UTV INC LED LIGHT BAR. POWDER COATED BLACK. USES 2 1¾" CLAMPS TO CLAMP ON TO ANY 1¾" TUBE. WILL FIT OUR: NUKE, ROCKET, EXPEDITION, AKIMBO CAGES FOR THE RZR AND THE OEM RZR CAGE AS WELL. Learn More
  1. Add to Wishlist
  1. UTV INC UNIVERSAL OFF ROAD CLAMP ON SUN VISOR
  2. $74.95
  3. Add to Cart
  4. ALL SIZES AVAILABLE Learn More
  1. Add to Wishlist
  1. UTV INC UNIVSERAL 1¾" BLACK HEADSET HANGER
  2. $57.95
  3. Add to Cart
  4. OUR NEW STYLE HEADSET HANGER WILL WORK ON ANY APPLICATION, SIDEWAYS, BACK WORDS, ETC. TURN THE CLAMP THE ANGLE YOU NEED IT AND TIGHTEN IT DOWN. WAA-LAA! BLACK ANODIZED FINISH WITH A 1¾" TUBE CLAMP. LONGER HOOKS TO ACCOMMODATE OVER THE HEAD PADDED HEADSETS. Learn More
  1. Add to Wishlist
  1. UTV INC VERTICAL GO PRO CLAMP ON MOUNT - BLACK
  2. $36.95
  3. Add to Cart
  4. UTV INC VERTICAL GO PRO CLAMP ON MOUNT - BLACK Learn More
  1. Add to Wishlist
  1. UTV INC VERTICAL WHIP / NMO ANTENNA MOUNT - MACHINED FINISH
  2. $39.95
  3. Add to Cart
  4. UTV INC 6061 T6 BILLET ALUMINUM SINGLE STRAP VERTICAL WHIP / NMO ANTENNA MOUNT - MACHINED FINISH Learn More
  1. Add to Wishlist
<LI class="item last even">
  1. UTV INC VERTICAL WHIP MOUNT - BLACK FINISH
  2. $39.95
  3. Add to Cart
  4. UTV INC 6061 T6 BILLET ALUMINUM SINGLE STRAP VERTICAL WHIP MOUNT - BLACK FINISH Learn More
  1. Add to Wishlist
Discussion Starter #2
  1. UTV INC POLARS RZR RZR-S RZR-XP RZR-4 CLAMP ON DASH BAR & 18" LED LIGHT BAR COMBO
  2. $624.90
  3. Add to Cart
  4. UTV INC POLARIS RZR CLAMP ON DASH BAR WITH 18" LED LIGHT TABS PAIRED WITH A PRIVATE LABEL 18" LED LIGHT. THIS COMBO IS DESIGNED TO LIGHT UP THE NIGHT AND LET YOU SEE ANYTHING AND EVERYTHING YOU NEED TO! BAR COMES POWDER COATED BLACK AS SHOWN. PLEASE CHOOSE RZR MODEL BELOW. Learn More
  1. Add to Wishlist
  1. UTV INC POLARS RZR-XP ROCKET ROLL CAGE
  2. $1,449.95
  3. Add to Cart
  4. Rocket Radius Cage for the XP ..it is 4" lower then the stock cage and built from .095 Wall DOM Steel, rear V-Bracing and aluminum roof .. and does not require use of a rear bumper and the bed mounts are for looks only and does not add any structural integrity .. this cage also will not allow the use of a Polaris RZR XP lock-n-ride box. Powder coat is extra $225.00 Learn More
  1. Add to Wishlist
  1. UTV INC POLISHED TURN DOWN TIPS FOR MUZZY DUAL EXHAUST
  2. $94.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  1. UTV INC RAW CLAMP ON UNIVERSAL LED / HID LIGHT MOUNT
  2. $34.95
  3. Add to Cart
  4. UTV INC RAW CLAMP ON UNIVERSAL LED / HID LIGHT MOUNT Learn More
  1. Add to Wishlist
  1. UTV INC RED 2011 POLARIS RZR RZR-S RZR-4 ALUMINUM GRILL - SLOTTED W/ LOGO
  2. $59.95
  3. Add to Cart
  4. UTV INC RED 2011 POLARIS RZR RZR-S RZR-4 ALUMINUM GRILL - SLOTTED W/ LOGO Learn More
  1. Add to Wishlist
  1. UTV INC RED 3" H STYLE PADDED SEWN TOGETHER STERNUM STRAP HARNESS RESTRAINT SYSTEM
  2. 1 Review(s)Add Your Review
  3. $119.95
  4. $99.95
  5. Add to Cart
  6. UTV INC IS HAPPY TO RELEASE OUR NEWEST HARNESS TO OUR LINE UP. THESE RED 3" H STYLE PADDED HARNESSES FEATURE A SEWN TOGETHER SHOULDER AND LAP BELT FOR EASIER ENTRY AND EXIT OF THE VEHICLE WITH ONLY HAVING 1 BUCKLE. THE STERNUM CLIP IN THE MIDDLE IS GREAT FOR USE ON STOCK SEATS OR SEATS THAT THE HARNESS WILL GO OVER THE SHOULDER BOLSTERS AND NOT THROUGH. THIS WILL ELIMINATE THE SHOULDER BELTS SLIDING OFF YOUR SHOULDERS ONCE BUCKLED IN. OUR NEWEST PADS ARE NOW LONGER AND SOFTER TO ALLOW AN EVEN MORE COMFORTABLE RIDING EXPERIENCE WHEN HARNESSED INTO THE MACHINE. ALSO, WE HAVE CHANGED FROM THE TRADITIONAL SILVER HARDWARE TO NEW ALL BLACK HARDWARE. REALLY MAKES THESE HARNESSES LOOK A LOT BETTER! SHOULDER BELTS FEATURE BOTH A MOUNTING TAB OR WRAP AROUND ATTACHMENT STYLE. Learn More
  1. Add to Wishlist
  1. UTV INC RIGID SR 10" BILLET GRILL MOUNT FITS 2011+ RZR XP MODELS
  2. $89.95
  3. Add to Cart
  4. UTV INC IS SUPER EXCITED TO LAUNCH OUR NEW BILLET GRILL MOUNT FOR THE RIGID 10" SINGLE ROW LED LIGHT BAR FOR THE 2011 + POLARIS RZR XP MODELS. THIS SIMPLE TO BOLT ON GRILL MOUNT WILL LET YOU ADD A 10" SR SERIES RIGID LED LIGHT BAR TO YOUR RZR XP WITH STYLE, CLASS AND FUNCTIONALITY. OPEN DESIGN ALLOWS MAXIMUM AIR FLOW TO THE RADIATOR WHILE GIVING YOU A STYLISH AND CUSTOM LOOK TO THE FRONT OF YOUR POLARIS RZR XP MODEL. GRILL WILL COME POWDER COATED BLACK. GRILL IS SHOWN WITH THE RIGID 10" SR SERIES LED LIGHT BAR. LED BAR IS NOT INCLUDED WITH THIS PRODUCT, IT IS AVAILABLE AS AN OPTION BELOW FOR A DISCOUNTED PRICE IF YOU WOULD LIKE TO MAKE THIS A KIT. Learn More
  1. Add to Wishlist
  1. UTV INC RZR 2 GAUGE KIT - WATER TEMP, OIL PRESSURE & DASH PLATE
  2. $309.95
  3. Add to Cart
  4. THIS BAD ASS KIT GIVES YOU EVERYTHING, AND I MEAN EVERYTHING YOU NEED TO ADD A WATER TEMP GAUGE AND AN OIL PRESSURE GAUGE. ALL FITTING, SENDING UNITS, SENDING UNIT ADAPTERS, LIGHT KITS FOR THE GAUGES, DASH PLATE, WIRING, DETAILED PHOTO INSTRUCTIONS, HOSE CLAMPS, ETC. THIS IS A 100% COMPLETE KIT. THE DASH PLATE IS AVAILABLE IN BRUSHED OR BLACK. PLEASE NOTE COLOR UPON CHECK OUT.Learn More
  1. Add to Wishlist
  1. UTV INC RZR HORN KIT
  2. $39.95
  3. Add to Cart
  4. HORN, PUSH BUTTON, WIRE HARNESS, ALL CONNECTORS PRE-CRIMPED, WIRE LOOM TO COVER THE WIRES AND INSTALLATION INSTRUCTIONS FOR A SUPER EASY INSTALL.
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP NUKE ROLL CAGE & REAR BUMPER - RAW
  2. 2 Review(s)Add Your Review
  3. $1,599.95
  4. Add to Cart
  5. MANUFACTURED FROM 1.75" .095 DOM TUBING AND TIG WELDED TO BEAUTIFUL PERFECTION. COMES STANDARD WITH 1 HEAVY DUTY WELDED ON WHIP TAB. 1 WELDED IN REAR VIEW MIRROR BUNG FOR 3/8-16 MIRROR. REAR BUMPER WITH HEAVY DUTY REAR GUSSET PLATE. CAGE IS 5" LOWER THAN STOCK. PRICE DOES NOT INCLUDE POWDER COAT. IT IS AVAILABLE FOR $300.00 Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP POLISHED BILLET REAR GUSSET PLATE
  2. $64.95
  3. Add to Cart
  4. UTV Inc. | Parts, Accessories, and Custom Built UTVs Introduces our new Polaris RZR 900 XP Rear Link Gusset Plate Made from ¼ Thick T-6 6061 Aircraft Grade Aluminum this CNC Machined Plate will and some extra strength to the rear mounting points.. it is also pre drilled for easy mounting of our optional LED License Plate frame and it will come Polished Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP REAR BUMPER - RAW
  2. $319.95
  3. Add to Cart
  4. REAR BUMPER FOR YOUR POLARIS RZR-XP WITH BUILT IN GUSSET PLATE WITH LICENSE PLATE HOLES TO ATTACH A LIGHTED FRAME TOO.
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP REAR FRONT LOWER A ARM GUSSET KIT
  2. $49.95
  3. Add to Cart
  4. Utvinc now has A-Arm Gussets for the Front Lower Rear A-Arm Mounts on the Polaris RZR XP Made From 10G Steel CNC CUT and Bent easy bolt on or you can sand away a little powder coat and weld these mounts on your XP to keep your A-Arm Bolts from egging out the stock A-Arm Mounts and to help from ripping the Arm right out of the stock mounts they come as a set and are supplied with Grade 10.9 and Grade 8 Hardware that is Zinc Plated Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP REAR GUSSET BRACE PLATE - BLK
  2. $59.96
  3. Add to Cart
  4. www.UTVinc.com Introduces our new Polaris RZR 900XP Rear Gusset Plate Made from ¼ Thick Mild Steel this massive gusset plate replaces the factory plate that is only .100 Thick it also bolts on at the top adding even more support for the rear Trailing arms and will give you a great location to mount a motorcycle sized License Plate. Comes Power Coated Black and is supplied with Hardware
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP REAR LICENSE PLATE FRAME MOUNTING KIT
  2. $14.95
  3. Add to Cart
  4. UTV INC POLARIS RZR-XP REAR LICENSE PLATE FRAME MOUNTING KIT Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP REAR TRAILING ARM GUSSET
  2. $99.95
  3. Add to Cart
  4. 2 PIECE TRAILING ARM GUSSET KIT FOR YOUR POLARIS RZR-XP Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP ROTOPAX MOUNT - STOCK CAGE - BLACK
  2. $129.95
  3. Add to Cart
  4. Fits the Stock XP cage and mounts the 3 gallon can above the oil tank so you dont lose bed space, gas can NOT included. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP WINCH MOUNT FRONT BUMPER
  2. $389.95
  3. Add to Cart
  4. FITS THE 2011 POLARIS RZR-XP AND UTILIZES MOUNTING HOLES: 3" x 6 5/8" 3 x 4 3/4" PRICE DOES NOT INCLUDE ANY POWDER COATING WILL SHIP RAW (BARE STEEL) UNLESS OTHER WISE PAID FOR. THE BILLET FAIR LEAD ON THE FRONT IS NOT INCLUDED. Learn More
  1. Add to Wishlist
  1. UTV INC POLARS RZR RATTLE BE GONE - PASSENGER GRAB HANDLE FIX
  3. $19.95
  4. Add to Cart
  5. Does your Polaris RZR Passenger Grab Handle Rattle like Crazy and drive you nuts like mine did ??? Heres a Cheap Easy Fix
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP FRONT BOLT ON GUSSET KIT
  2. $237.75
  3. Add to Cart
  4. INCLUDES: UTV INC POLARIS RZR-XP FRONT UPPER REAR GUSSETS UTV INC POLARIS RZR-XP REAR FRONT LOWER A ARM GUSSET KIT UTV INC POLARIS RZR-XP 2012 UPPER A ARM GUSSET - BLACK UTV INC POLARIS RZR-XP FRONT LOWER A ARM GUSSET PLATE UTV INC POLARIS RZR-XP FRONT UPPER SHOCK MOUNT GUSSET Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP FRONT BUMPER - RAW
  2. $324.95
  3. Add to Cart
  4. UTV Inc. | Parts, Accessories, and Custom Built UTVs Introduces our new Polaris RZR 900 XP Front Bumper, Install is a easy bolt on..and will come supplied with install hardware. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP FRONT LOWER A ARM GUSSET PLATE
  2. $69.95
  3. Add to Cart
  4. UTV Inc. | Parts, Accessories, and Custom Built UTVs Introduces our new Polaris RZR XP Front Lower A-Arm Gusset Kit. Not only will it add some major beef to the Stock A-Arm Mounts it will also keep your mounting holes from stretching and becoming egg shaped. It is CNC Cut and Bent and is made from 10 G. Mild Steel Cold Rolled Sheet, It comes Powder Coated Black and is Supplied with Grade 10.9 Zinc Plated Hardware Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP FRONT UPPER A-ARM GUSSET PLATE (2011 ONLY)
  2. $27.95
  3. Add to Cart
  4. UTV Inc. | Parts, Accessories, and Custom Built UTVs Introduces our new Polaris RZR 900 XP Front Gusset Plate. This item will make your front upper a-arm mounts over 2 times thicker and stronger and is a must have for anybody that Plans on Haulin Ass .. if you bought your XP just cause its perdy you wont be needing this… It will come Powder Coated black it is made from 10 Gage Mild Steel. Will only fit the 2011 model, will not fit 2012. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP FRONT UPPER REAR GUSSETS
  2. $49.95
  3. Add to Cart
  4. UTV INC POLARIS RZR-XP FRONT UPPER REAR GUSSETS. WILL NOT WORK WITH WINCH MOUNTS. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP FRONT UPPER SHOCK MOUNT GUSSET
  2. $39.95
  3. Add to Cart
  4. Do you Drive your RZR XP like a crazed wildman man ? Trying to get airborn off every bump in the road ? hit the woops at 75 mph with no regard for life or limb ... yep your a wildman and you will be wanting this new 10 G. Steel front upper shock reinforcement from UTVinc.com comes powder coated Black and is supplied with yellow Zinc plated Grade 8 Hardware and Nylon Lock Nuts Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP HEAT SHIELD
  2. $42.95
  3. Add to Cart
  4. Introducing our new Polaris RZR XP Exhaust Heat Shield and gap seal. It is available in brushed aluminum finish and is made from 5052 Aluminum Sheet that is .063 Thick, It comes with Cool It Thermo shield installed. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP HEAVY DUTY TIE ROD KIT - PR
  2. $269.95
  3. Add to Cart
  4. they are nothing short of super heavy duty Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP LOCK AND RIDE 36 PACK COOLER RACK COMBO KIT
  2. $499.95
  3. Add to Cart
  4. WE MADE THESE FOR A CUSTOMER AND HAVE BEEN GETTING CALLS ASKING FOR THEM, SO WE MADE A COUPLE EXTRAS. 3/8" UHMW BASE MOUNTING PLATE WITH 6) UTV INC KNOB & RIDE LOCK & RIDE MOUNTING SYSTEM. 3) UTV INC 12 PACK COOLER RACK COMBOS. Learn More
  1. Add to Wishlist
  2. $237.75
  3. Add to Cart
  1. Add to Wishlist
  2. $324.95
  3. Add to Cart
  1. Add to Wishlist
  2. $69.95
  3. Add to Cart
  1. Add to Wishlist
  2. $27.95
  3. Add to Cart
  1. Add to Wishlist
  2. $49.95
  3. Add to Cart
  1. Add to Wishlist
  2. $39.95
  3. Add to Cart
  1. Add to Wishlist
  2. $42.95
  3. Add to Cart
  1. Add to Wishlist
  2. $269.95
  3. Add to Cart
  1. Add to Wishlist
  2. $499.95
  3. Add to Cart
  1. Add to Wishlist
Discussion Starter #6
  1. UTV INC POLARIS RZR-XP 900 EXPEDITION CAGE & BUMPER - RAW
  2. $1,499.95
  3. Add to Cart
  4. 1¾" .095 wall DOM Steel Tig Welded. Includes 1 3/8-16 Mirror Bung, 1 HD Whip Tab. Cage and Rear Bumper ONLY - BARE STEEL Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP 900 REAR CLAMP ON ADD ON ROLL CAGE
  2. $274.95
  3. Add to Cart
  4. THE BEST ADD ON REAR CAGE IN THE INDUSTRY FOR YOUR POLARIS RZR-XP. THIS CAGE IS CONSTRUCTED OF 1¾" .095 WALL MILD STEEL AND IS TIG WELDED TO BEAUTIFUL PERFECTION. UTILIZING THE UTV INC HEAVY DUTY CLAMP IT EASILY ATTACHES TO THE TOP OF THE ROLL CAGE WITH 12 ALLEN HEAD BOLTS. WE THEN INCORPORATED THE UTV INC RZR REAR GUSSET PLATE FOR ANOTHER ATTACHMENT POINT ON THE BOTTOM. STRONG, DURABLE, AND IT LOOKS DANG GOOD! THE BASE MODEL IS SHOWN. THE PRICE SHOWN IS FOR BARE STEEL (NO POWDER COAT). PLEASE SELECT THE OPTIONS YOU WOULD LIKE BELOW. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP 900 REAR UPPER SHOCK GUSSET
  2. $79.95
  3. Add to Cart
  4. SO AFTER PUTTING ON SOME COGNITOS AND ELKAS AND KINGS WE NOTICED THE TOP SHOCK TOWER WAS SHOWING SOME SIGNS OF WEAR AND FLEX. THUS COMES INTO PLAY A GUSSET TO HELP PREVENT THE REAR FRAME AND SHOCK MOUNTING POINT FROM FLEXING TO MUCH OR CRACKING THE WELDS. MADE FROM 1/8" STEEL, FORMED AND TIG WELDED THEN POWDER COATED TO PERFECTION. COMES WITH DRIVER AND PASSENGER SIDE GUSSETS, HARDWARE AND INSTRUCTIONS. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP 900 THROTTLE BODY MOUNTING PLATE
  2. $26.95
  3. Add to Cart
  4. UTV INC POLARIS RZR-XP 900 THROTTLE BODY MOUNTING PLATE. Keep those throttle bodies from bouncing around with this great mount from UTVinc.com Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP 900 XP4 UHMW TRAILING ARM SLIDERS - PAIR
  2. $179.95
  3. Add to Cart
  4. UHMW ROCK SLIDERS FOR THE POLARIS RZR-XP TRAILING ARMS Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP AIR INTAKE LID SPACER
  2. $29.95
  3. Add to Cart
  4. CNC waterjet cut aluminum intake spacer for rzr-xp Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP BED SIDE BILLET LOCK AND RIDE WHIP MOUNT
  2. $49.44
  3. Add to Cart
  4. BILLET LEVER STYLE LOCK AND RIDE WITH BILLET FLAG HOLDER Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP BILLET WINCH FAIRLEAD - BLACK
  2. $34.95
  3. Add to Cart
  4. UTV Inc. | Parts, Accessories, and Custom Built UTVs Introduces our new Billet Aluminum Winch Fairlead for use with synthetic winch rope these bolt right up to our Polaris RZR Winch Mount front bumpers a are offer in either raw finish or black anodized made from T-6 6061 Billet Aluminum. Bolt holes are 6" Center to Center Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP BILLET WINCH FAIRLEAD - RAW
  2. $34.95
  3. Add to Cart
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP EXHAUST COVER - BLACK
  2. $44.95
  3. Add to Cart
  4. PUTTING AN AFTERMARKET EXHAUST ON YOUR MACHINE!? DONT WANT IT TO LOOK NAKED AND UGLY WITH AN EXPOSED REAR END!? THEN THE UTV INC EXHAUST COVER IS THE ANSWER. POWDER COATED BLACK AND ALL MOUNTING HARDWARE COMES WITH IT TO MAKE A CLEAN AND SIMPLE INSTALLATION AND COVERS THE REAR OF YOUR MACHINE. SHOWN WITH AND WITH OUT THE COVER. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP FRONT A ARM DELRIN BUSHING KIT
  3. $99.95
  4. Add to Cart
  5. DELRIN BUSHING KIT FOR RZR-XP Learn More
  1. Add to Wishlist
Discussion Starter #7
  1. UTV INC POLARIS RZR XP XP4 900 REAR LED LIGHTED LICENSE PLATE KIT
  2. $42.95
  3. Add to Cart
  4. NEED TO ADD A LICENSE PLATE MOUNT AND LIGHT TO YOUR RZR XP OR RZR XP4? THIS NIFTY EASY TO USE, EASY TO WIRE UP LED LIGHTED LICENSE PLATE MOUNT COMES WITH EVERYTHING YOU NEED EXCEPT THE RZR AND THE PLATE. ALUMINUM MOUNT POWDER COATED BLACK FOR A LIFELONG DURABLE FINISH. THE LED IS SUPER BRIGHT WHITE AND WILL ILLUMINATE TO GIVE A CLEAR VIEW OF THE PLATE NUMBER WHEN INSTALLED ON THE BACK OF THE MACHINE. NO CUTTING, NO DRILLING, NO MODIFICATION REQUIRED. COMES WITH EVERYTHING YOU NEED, EVEN INSTRUCTIONS! Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP & 570 GRILL - SLOTTED DESIGN - BRUSHED
  2. $54.95
  3. Add to Cart
  4. UTV INC 2012 POLARIS RZR GRILL - SLOTTED DESIGN - BRUSHED Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP & 570 GRILL - SLOTTED W/ LOGO DESIGN - BRUSHED
  2. $49.95
  3. Add to Cart
  4. UTV INC 2012 POLARIS RZR GRILL - SLOTTED W/ LOGO DESIGN - BRUSHED Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP & 570 GRILL - SPIDER WEB DESIGN - BRUSHED
  2. $69.95
  3. Add to Cart
  4. UTV INC 2012 POLARIS RZR GRILL - SPIDER WEB DESIGN - BRUSHED Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP & 570 GRILL - STAR DESIGN - BRUSHED
  2. $69.95
  3. Add to Cart
  4. UTV INC 2012 POLARIS RZR GRILL - STAR DESIGN - BRUSHED Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP 10" LED LIGHT BAR FRONT MOUNT
  2. $39.95
  3. Add to Cart
  4. www.UTVinc.com Introduces our new Polaris RZR 900 XP 10” LED Lightbar Mount This item only works with the UTVinc 10” LED Light bar making install a easy bolt on..and will come Powder coated black it is made from 10 Gage Mild Steel and supplied with install hardware.
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP 2" RECEIVER HITCH REAR GUSSET PLATE - BLK
  2. $84.95
  3. Add to Cart
  4. UTV Inc. | Parts, Accessories, and Custom Built UTVs Introduces our new Polaris RZR 900 XP Rear Gusset Plate with 2” Receiver. This item will not only reinforce your rear radius rod mounts but also allow you to tow a trailer, it also uses mounting points on the rzr frame and is made for ¼ Thick mild steel ..and will come Powder coated black and supplied with install hardware. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP 2012 UPPER A ARM GUSSET - BLACK
  2. $27.95
  3. Add to Cart
  4. UTV INC POLARIS RZR-XP 2012 UPPER A ARM GUSSET - BLACK Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP 3/8" UHMW SKID PLATE
  2. $419.95
  3. Add to Cart
  4. UTV INC POLARIS RZR-XP 3/8" UHMW SKID PLATE Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR-XP 900 2 PC FRAME TUBE GUSSET KIT
  3. $134.95
  4. $99.95
  5. Add to Cart
  6. GIVE YOUR XP'S FRAME SOME EXTRA STRENGTH BY ADDING THE UTV INC 2 PIECE FRAME TUBE KIT. SIMPLY SLIDE THEM IN AND YOURE READY TO TACKLE THE TOUGHEST TERRAIN Learn More
  1. Add to Wishlist
Discussion Starter #8
  2. $42.95
  3. Add to Cart
  1. Add to Wishlist
  2. $54.95
  3. Add to Cart
  1. Add to Wishlist
  2. $49.95
  3. Add to Cart
  1. Add to Wishlist
  2. $69.95
  3. Add to Cart
  1. Add to Wishlist
  2. $69.95
  3. Add to Cart
  1. Add to Wishlist
  2. $39.95
  3. Add to Cart
    Learn More
  1. Add to Wishlist
  2. $84.95
  3. Add to Cart
  1. Add to Wishlist
  2. $27.95
  3. Add to Cart
  1. Add to Wishlist
  2. $419.95
  3. Add to Cart
  1. Add to Wishlist
  3. $134.95
  4. $99.95
  5. Add to Cart
  1. Add to Wishlist
Discussion Starter #9
  1. UTV INC POLARIS RZR XP & XP 4 15 PIECE STEEL FRONT WELD ON GUSSET KIT
  2. $624.90
  3. Add to Cart
  4. WANT A LITTLE MORE BEEFY FRONT END ON YOUR RZR XP OR RZR XP 4 ? THIS 15 PIECE WELD IN GUSSET KIT WILL GIVE YOU JUST THAT. LASER CUT FROM STEEL THESE PARTS WILL DOUBLE THE TABS AND TRIANGULATE THEM TO THE CHASSIS WHEN WELDED ON. ALSO, FRAME STRENGTHENING TRIANGULAR GUSSETS ARE INCLUDED AS WELL. COMES WITH THE 15 PIECES SHOWN AND AN DIAGRAM WHERE WHERE PART GETS WELDED IN. FITS 2011+ RZR XP AND XP 4 900 MODELS. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR XP & XP 4 UNDER BED HEAT SHIELD - 3 PC KIT
  2. $109.95
  3. Add to Cart
  4. We are super excited to bring to you our newest product to the already extensive line up of RZR parts. This RZR-XP and XP-4 900 3 pc under bed heat shield kit will allow you to keep the top of your bed nice and cool so your beverages stay colder for longer. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR XP & XP 4 WALKER EVANS REAR PASSENGER SHOCK HEAT SHIELD
  2. $53.95
  3. Add to Cart
  4. TIRED OF THE REAR SHOCK FADE FROM THE RESERVOIR GETTING HOT BECAUSE THE EXHAUST RUNS RIGHT NEXT TO IT? WELL WE CAME UP WITH A SOLUTION!! THE UTV INC POLARIS RZR XP MODEL REAR PASSENGER SHOCK HEAT SHIELD IS DESIGNED TO HELP KEEP THE HEAT OF THE MOTOR AND EXHAUST AWAY FROM THE SHOCK TO HELP KEEP THE SHOCK PERFORMING. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR XP & XP4 BILLET ALUMINUM BED VENT
  2. $299.95
  3. Add to Cart
  4. UTV Inc is proud to announce our new billet aluminum bed vent for your 900 RZR models. 0.250 inch thick 6061 T6 aluminum plate now features lock and ride holes in the OEM positions so all L&R accessories will work as stock. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR XP & XP4 PASSENGER REAR FOX SHOCK HEAT SHIELD
  2. $39.95
  3. Add to Cart
  4. HAVE YOU EVER WENT FOR A RIDE AND REALIZED AFTER A WHILE THE REAR PASSENGER SHOCK WAS FADING REALLY BAD? ME TOO! THE EXHAUST THAT PASSES RIGHT NEXT TO THE FOX SHOCK PUTS OFF SOME SERIOUS HEAT AND THE SHOCK WILL START TO FADE EARLIER UNDER A LOAD. THIS HEAT SHIELD HELPS KEEP THE HEAT AWAY AND LETS YOU KEEP RIDING FOR LONGER WITHOUT THE FADE. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR XP 24 PACK COOLER RACK COMBO
  2. $184.90
  3. Add to Cart
  4. well our 12 pack cooler just aint big enough for some of you guys so we are working on a new 24 Pack Rack Package that will work with a Lock and Ride Box on the new XP or you can shit can the lock and ride box and run 2 of these bad boys in the bed ... or 1 24 pack rack and our 2.8 Gallon Knob and Ride Gas Can and Mount or 1 24 pack rack and our 12 Pack Rack .. Includes: American Outdoors 24 pack cooler - black UTV Inc 24 pack cooler rack - black UTV Inc 3 lock and ride knobs UTV Inc cooler hold down strap Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR XP 7075 BILLET ALUMINUM REAR RADIUS RODS
  2. $399.95
  3. Add to Cart
  4. UTV INC POLARIS RZR XP 7075 BILLET ALUMINUM REAR RADIUS RODS Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR XP 900 2 SEAT KRYPTONITE ROLL CAGE
  2. $1,749.95
  3. Add to Cart
  4. 1.75" 0.095 DOM STEEL TUBING. TIG WELDED. 1 HEAVY DUTY WHIP MOUNT. REAR VIEW MIRROR BUNG. RADIUS A/C PILLAR DESIGN. RADIUS ROOF AND WINDOW V BRACING. BEAD ROLLED ALUMINUM ROOF WITH DRIP EDGE. QUARTER TURN DZUS FASTENERS TO ATTACH ROOF. REAR BUMPER WITH 4 EXTRA ATTACHMENT MOUNTS TO CHASSIS FOR STRENGTH. HEAVY DUTY REAR RADIUS ROD GUSSET PLATE. PRICE IS FOR A RAW (BARE STEEL, NO POWDER COAT) CAGE, ROOF AND REAR BUMPER. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR XP 900 CLUTCH PULLER
  2. $59.95
  3. Add to Cart
  4. UTV INC POLARIS RZR XP 900 CLUTCH PULLER Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR XP NERF BARS (YOUR CHOICE OF COLOR)
  3. $349.95
  4. Add to Cart
  5. UTV INC Introduces our new Polaris RZR XP NERF BARS. They are made from 1 ¼” .095 Mild Steal and 3/16 Mild Steel Plate, These Bad Ass Nerf Bars will come with all mounting hardware and do require you drill some holes for installation. Learn More
  1. Add to Wishlist
Discussion Starter #10
  2. $624.90
  3. Add to Cart
  1. Add to Wishlist
  2. $109.95
  3. Add to Cart
  1. Add to Wishlist
  2. $53.95
  3. Add to Cart
  1. Add to Wishlist
  2. $299.95
  3. Add to Cart
  1. Add to Wishlist
  2. $39.95
  3. Add to Cart
  1. Add to Wishlist
  2. $184.90
  3. Add to Cart
  1. Add to Wishlist
  2. $399.95
  3. Add to Cart
  1. Add to Wishlist
  2. $1,749.95
  3. Add to Cart
  1. Add to Wishlist
  2. $59.95
  3. Add to Cart
  1. Add to Wishlist
  3. $349.95
  4. Add to Cart
  1. Add to Wishlist
Discussion Starter #11
  1. UTV INC POLARIS RZR RZR4 RZRS RZRXP RZRXP4 800 900 BED SIDE SPARE TIRE MOUNT
  2. $159.95
  3. Add to Cart
  4. DESIGNED TO WORK WITH THE OEM TIRE AND THE OEM ROLL CAGE. FITS ALL RZR MODELS. AVAILABLE IN BLACK OR SILVER. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR S 4 XP 12V RELOCATION BRACKET
  2. $19.95
  3. Add to Cart
  4. BRACKET TO RELOCATED THE 12V PLUG OUT OF THE DASH AND MOVE IT UNDER THE DASH. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR S 4 XP 5 SWITCH DASH PLATE
  2. $59.95
  3. Add to Cart
  4. SWITCH PLATE FOR YOUR POLARIS RZR RZR-S RZR-4 RZR-XP. PLEASE SELECT THE YEAR OF YOUR RZR FOR THE 12V RELOCATION BRACKET. RED, BLUE, BLACK OR MACHINED FINISH AVAILABLE. SWITCHES ARE NOT INCLUDED! Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR SEAT LATCH RELEASE LEVERS - RED
  2. $49.95
  3. Add to Cart
  4. UTV INC POLARIS RZR SEAT LATCH RELEASE LEVERS - RED. WILL NOT WORK WITH STOCK SEATS OR SEAT BELTS. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR SWITCH PLATE & LED SWITCH COMBO
  2. $54.95
  3. Add to Cart
  4. EVERYONE WAS ASKING FOR A CHEAPER ALTERNATIVE TO THE STANDARD CNC MACHINED SWITCH PLATES THAT ARE CUT, ANODIZED AND THEN RECUT FOR THAT SIGNATURE UTV INC LOOK. SO WE GIVE YOU THE UTV INC RZR SWITCH PLATE COMBO. INCLUDES 1 (ONE) POWDER COATED BLACK ALUMINUM DASH PLATE W/ YOUR CHOICE OF 3 LED SWITCHES. THE SWITCHES ARE ON OFF, 21 AMP, WEATHER RESISTANT SWITCHES. THEY COME IN RED, BLUE, GREEN OR ORANGE. HARDWARE TO MOUNT THE PLATE IS INCLUDED. INSTRUCTIONS AND WIRING DIAGRAM NOT INCLUDED. PLEASE CHOOSE THE COLOR OF YOUR SWITCHES BELOW: Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR VERTICAL DASH PLATE - BLACK - 1 SWITCH - DRIVER
  2. $84.95
  3. Add to Cart
  4. BILLET ALUMINUM DASH PLATE, ANODIZED BLACK AND CUT OUT FOR 1 ROCKER SWITCH ON THE DRIVER SIDE. STAINLESS BUTTON HEAD HARDWARE INCLUDED. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR VERTICAL DASH PLATE - BLACK - 1 SWITCH - PASSENGER
  2. $84.95
  3. Add to Cart
  4. BLACK ANODIZED BILLET DASH PLATE WITH 1 ROCKER SWITCH ON THE PASSENGER SIDE. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR VERTICAL DASH PLATE - BLACK - 2 SWITCHES
  2. $84.95
  3. Add to Cart
  4. BLACK ANODIZED ALUMINUM DASH PLATES FOR YOUR POLARIS RZR TO ADD 2 MORE ROCKER SWITCHES FOR ALL YOUR OTHER AWESOME GOODIES ON YOUR MACHINE. STAINLESS BUTTON HEAD HARDWARE IS INCLUDED. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR VERTICAL DASH PLATE - BLACK - NO SWITCH
  2. $84.95
  3. Add to Cart
  4. ALUMINUM DASH TRIM PLATES TO DRESS THE DASH UP. ANODIZED BLACK AND THEN RECUT AROUND THE EDGES. STAINLESS STEEL BUTTON HEAD HARDWARE INCLUDED. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR WIDE DOOR CARBON FIBER VINYL LINERS
  2. $99.95
  3. Add to Cart
  4. We have been doing a bunch of these Custom cut Black Carbon Fiber, or White Carbon Fiber and Ostrich Vinyl Door Liners on our wide UTVinc Doors in the last few weeks so I figured id offer them up to you guys for your custon builds .. the Material is CNC cut for a Perfect Fit on our wide doors and is 1/4 Trimmed all the way around the edges all you need is a can of 3M Spray Glue and 3M adhesive remover for any over spray when installing The Price For a complete set..the two main doors and the quarter panels is 100.00 and it looks great on the inside of the doors and also helps deaden the metal sound of the doors Learn More
  1. Add to Wishlist
Discussion Starter #12
  1. UTV INC POLARIS RZR RUGGED RADIO AND 2 WAY INTERCOM MOUNT
  2. $39.95
  3. Add to Cart
  4. UTV INC POLARIS RZR RUGGED RADIO AND 2 WAY INTERCOM MOUNT
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RZR-S 800 RZR-XP 900 WIDE SUICIDE OPENING REMOVABLE DOORS
  2. 4 Review(s)Add Your Review
  3. $659.95
  4. Add to Cart
  5. Opening doors with A automotive style Latch. Steel frame, aluminum panel, Suicide opening, lift off removable. Price is for a PAIR.
    Video of them in action:
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RZR-S RZR-4 A PILLAR LIGHT MOUNTS - BLK
  2. $39.95
  3. Add to Cart
  4. 10 Ga. Mild Steel Powder Coated Black Easy Bolt on install. Will not work with clamp on dash bars or cages with a welded in dash bar as it pushes the bungs to far apart. Sold as a PAIR
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RZR-S RZR-4 LED TURN SIGNAL KIT
  2. $159.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RZR-S RZR-4 RZR-XP NUVI GPS STEERING WHEEL MOUNT
  3. $69.95
  4. Add to Cart
  5. Fits Garmin nuvi 220, 500, 510, 550 & zumo 220. Silver & Black available, please choose below. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RZR-S RZR-4 RZR-XP RZR-XP4 RADIATOR FAN OVER RIDE SWITCH
  2. 3 Review(s)Add Your Review
  3. $32.95
  4. Add to Cart
  5. UTV INC POLARIS RZR RZR-S RZR-4 RZR-XP RZR-XP4 RADIATOR FAN OVER RIDE SWITCH Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RZR-S RZR-XP LOW BOY HALF STYLE OPENING SUICIDE REMOVABLE DOORS - BLACK
  2. $659.95
  3. Add to Cart
  4. UTV INC IS PROUD TO RELEASE OUR NEWEST PRODUCT TO THE LINE UP! CONSTRUCTED OF STEEL TUBING, WITH ALUMINUM DOOR SKINS AND TIG WELDED TO PERFECTION, THESE RZR OPENING DOORS ARE SURE TO COMPLIMENT AND IMPROVE THE SAFETY FACTOR OF YOUR POLARIS RZR. DOOR FRAME AND DOOR SKIN IS POWDER COATED BLACK FOR A DURABLE FINISH. THE INNER HINGED PANEL AND FRAME IS REMOVABLE FOR THOSE THAT WANT A MORE OPEN RIDE ONCE IN A WHILE OR IF YOU HAVE AN ENCLOSED TRAILER AND DONT WANT TO RICKY BOBBY IT OUT THE MACHINE. THESE DOORS FEATURE THE UTV INC STANDARD 2 POSITION AUTOMOTIVE STYLE LOCKING "SLAM" LATCH. SIMPLY SHUT THE DOOR JUST LIKE YOU WOULD ON YOUR CAR OR TRUCK AND THE LATCH WILL MAKE SURE IT STAYS CLOSE. EASY OPEN 1 FINGER BILLET ALUMINUM LEVEL ADDS STYLE WHILE GIVING YOU THE EASE OF ENTRY AND EXIT. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RZR-S RZR-XP RZR-4 COOLER RACK - BLACK
  2. $61.95
  3. Add to Cart
  4. NEW ALUMINUM LIGHT WEIGHT COOLER RACK FOR ALL MODEL RZR'S. COMES POWDER COATED BLACK AND HAS A VELCRO STRAP FOR A COOLER. USES LOCK AND RIDE MOUNTING STYLE HARDWARE. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RZR-S RZR-XP RZR-4 RZR-XP4 SEAT LOWERING BASES - PAIR
  2. $124.95
  3. $99.95
  4. Add to Cart
  5. PAIR OF STEEL BASES MADE TO LOWER THE SEATS ON YOUR POLARIS RANGER RZR MODEL. FITS ALL 800 AND 900 MODEL RZRS. WILL NOT WORK ON THE FACTORY OEM SEATS. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RZR-S RZR-XP SHORTY RACE STYLE FRONT BUMPER
Discussion Starter #13
  1. UTV INC POLARIS RZR iPod TOUCH 4TH GEN BILLET STEERING WHEEL MOUNT
  2. $79.95
  3. Add to Cart
  4. DO YOU NEED A TRICK BILLET ALUMINUM MOUNT FOR YOUR 4TH GEN iPod TOUCH ON YOUR POLARIS RZR? WELL I DID, SO WE MADE THIS 6061 BILLET ALUMINUM CLAMP ON IPHONE MOUNT. USING A RAM MOUNT AND OUR BILLET CLAMP AND BACKING PLATE THIS WILL MOUNT TO THE STEERING COLUMN YOUR POLARIS RZR 800, RZR 570, RZR-S, RZR-XP, RZR-4 OR RZR-XP4. WILL NOT FIT AN IPHONE 4 OR 4S WHILE USING A CASE. PART COMES IN A MACHINED FINISH AS SHOWN. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR LEXAN WIND DEFLECTOR SHIELD
  2. $124.95
  3. Add to Cart
  4. UTV INC IS EXCITED TO BRING YOU OUR NEWEST WINDSHIELD TO THE LINE UP! THIS WIND DEFLECTOR WILL WORK ON OEM AND AFTERMARKET ROLL CAGES AND PROVIDES A SMALLER WIND SHIELD OVER OUR STANDARD HALF / QUARTER SHIELD. THIS ALLOWS THE MOST VISIBILITY WILL STILL ALLOWING THE WIND TO DEFLECT UP AND OVER YOUR FACE. MADE FROM 1/4" SCRATCH RESISTANT COATED LEXAN. WE PROVIDE YOU WITH 4 CUSHIONED STAINLESS STEEL TUBE CLAMPS TO BOLT THE WINDSHIELD ONTO YOUR MACHINE WITH OUR DAMAGING OR SCRATCHING YOUR POWDER COAT. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR LOCK AND RIDE COOLER RACK & COOLER COMBO BLK/BLK
  2. $124.95
  3. Add to Cart
  4. BLACK POWDER COATED COOLER RACK WITH 2 LOCK AND RIDE KNOBS & BLACK AMERICAN OUTDOOR 12 PACK OFFROAD COOLER WITH SIDE POCKET AND UTV INC LOGO Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR LOWRANCE ELITE 5M GPS DASH PLATE
  2. $189.95
  3. Add to Cart
  4. WANT TO PUT A 5" LOWRANCE GPS IN YOUR RZR BUT DONT WANT IT TO LOOK ALL HOKEY POKEY LIKE THE OEM DASH PLATE?!?! US TOO.. ITS OKAY, YOU CAN SAY IT... THE POLARIS ONE IS HIDEOUS. THIS RZR DASH PLATE WILL HOLD THE OEM SPEEDO, THE IGNITION SWITCH, 6 TOTAL SWITCHES (THE STOCK 2 PLUS 4 EXTRA) AND THE 12V ACCESSORY PLUG. THIS DASH PLATE REQUIRES EXTENSIVE CUTTING AND MODIFICATION OF YOUR DASH. IT WILL INCLUDE THE DASH PLATE SHOWN BELOW AND THE HARDWARE NEEDED TO BOLT IT DOWN. NO INSTRUCTIONS INCLUDED AND THIS WILL ONLY FIT ELITE 5M. THIS IS A CUSTOM ORDER ITEM AND WILL TAKE A WEEK OR SO TO MAKE. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR MONTANA BILLET GPS MOUNT
  2. $79.95
  3. Add to Cart
  4. ADDING A GPS TO YOUR RZR AND NEED A MOUNT? WELL HERE YA GO! THIS BILLET MOUNT WILL HOLD YOUR GARMIN MONTANA GPS ON THE STEERING COLUMN. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR OIL PRESSURE GAUGE KIT & DASH TRIM PLATE
  2. $199.95
  3. Add to Cart
  4. THIS KIT WILL INCLUDE EVERYTHING YOU NEED TO ADD AN OIL PRESSURE GAUGE TO YOUR RZR AS WELL AS A BALLER DASH TRIM PLATE TO HOUSE THE GAUGE. THE DASH TRIM IS AVAILABLE IN BLACK OR BRUSHED ALUMINUM FINISH. INCLUDES BLACK AUTO METER GAUGE, WIRING, ADAPTER, FITTINGS, SENDING UNIT, INSTRUCTIONS, DASH PLATE, EVERYTHING NEEDED.Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR PCI 2 WAY RADIO & INTERCOM MOUNT
  2. $39.95
  3. Add to Cart
  4. OUR EVER POPULAR RUGGED RADIO 2 WAY ADJUSTABLE RADIO MOUNT IS NOW AVAILABLE FOR THE PCI RADIO AND INTERCOM TOO !! ADJUSTABLE FROM LEFT TO RIGHT AND ABLE TO ANGLE THE FACES TWORDS THE DRIVER OR PASSENGER AS WELL. MANUFACTURED OUT OF ALUMINUM AND POWDER COATED FOR A LIFE LONG DURABLE FINISH. BOLTS UP TO THE POLARIS RZR MODELS. ** RADIO AND INTERCOM NOT INCLUDED ** Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR POLISHED PISTOL GRIP SHIFTER LEVER HANDLE
  2. $40.95
  3. Add to Cart
  4. THIS POLISHED SHIFT KNOB IS COOLER THAN A TREX DOING THE BACKSTROKE AT THE COUNTY POOL. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR QUARTER DOORS (PR) - BLACK
  2. $189.95
  3. Add to Cart
  4. UTV INC POLARIS RZR QUARTER DOORS - BLACK
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RED ANODIZED BILLET CUP HOLDERS - PAIR
  2. $99.95
Add to Cart
Discussion Starter #14
  1. UTV INC POLARIS RZR BLUE SHIFTER ARM & BLACK SHIFT HANDLE - LIMITED EDITION
  2. $139.95
  3. Add to Cart
  4. MADE FROM 6061 T6 BILLET ALUMINUM AND MACHINED TO PRECISION PERFECTION. THIS BILLET SHIFTER ARM & HANDLE WILL BE SURE TO BRING THAT FLARE INTO YOUR CAB AREA TO BRING THAT DULL INTERIOR TO LIFE! WE ALSO PAIR THIS ITEM WITH THE DELRIN SHIFTER BUSHINGS FOR LONG LASTING GEAR SHIFTING. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BMF ROLL CAGE PACKAGE
  2. $2,399.95
  3. Add to Cart
  4. MADE FROM 1¾" .095 DOM STEEL AND TIG WELDED. FRONT AND REAR HIGH MOUNT WINCH BUMPERS. RADIUS DESIGN. ALUMINUM ROOF WITH DZUS BUTTONS. 3/8 MIRROR BUNG. HEAVY DUTY WHIP MOUNT. PRICE IS FOR A RAW CAGE AND BUMPERS. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BOLT ON FLASH LIGHT ACCESSORY HOLDER
  2. $39.95
  3. Add to Cart
  4. UTV INC POLARIS RZR BOLT ON FLASH LIGHT ACCESSORY HOLDER Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR CENTER OF BED COOLER RACK - RAW
  2. $99.95
  3. Add to Cart
  4. UTV INC HAS DESIGNED THE MOST BALLER-TASTIC COOLER RACK FOR YOUR POPO RZR. IT ATTACHES TO THE CENTER OF THE BED OF THE RZR USING THE 4 EXISTING OEM BOLTS THAT HOLD THE BED TO THE FRAME OF YOUR RZR. ONCE THIS THING IS BOLTED DOWN, ITS NOT GOING ANY WHERE! SHIPS IN RAW (BARE STEEL) FINISH. POWDER COATING AVAILABLE FOR AN EXTRA FEE.
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR DASH BAR W/ V BRACING & LIGHT BAR
  2. $259.95
  3. Add to Cart
  4. DASH BAR WITH INTRUSION V BRACING AND A LIGHT BAR WITH 4 LIGHT TABS. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR DELRIN BRAKE PEDAL BUSHING KIT
  2. $19.95
  3. Add to Cart
  4. REPLACE THOSE OLD WORN OUT BUSHINGS FOR THESE DELRIN ONES. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR DELRIN SHIFTER BUSHING KIT
  2. $19.95
  3. Add to Cart
  4. REPLACE THOSE OLD WORN OUT CRAPPY BUSHING FOR THESE DELRIN ONES. WE'RE AWESOME.
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR IPHONE 4 4S BILLET STEERING WHEEL MOUNT
  2. $79.95
  3. Add to Cart
  4. DO YOU NEED A TRICK BILLET ALUMINUM MOUNT FOR YOUR IPHONE 4 OR 4S ON YOUR POLARIS RZR? WELL I DID, SO WE MADE THIS 6061 BILLET ALUMINUM CLAMP ON IPHONE MOUNT. USING A RAM MOUNT AND OUR BILLET CLAMP AND BACKING PLATE THIS WILL MOUNT TO THE STEERING COLUMN YOUR POLARIS RZR 800, RZR 570, RZR-S, RZR-XP, RZR-4 OR RZR-XP4. WILL NOT FIT AN IPHONE 4 OR 4S WHILE USING A CASE. PART COMES IN A MACHINED FINISH AS SHOWN. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR IPHONE 5 BILLET STEERING WHEEL MOUNT
  2. $624.90
  3. Add to Cart
  4. DO YOU NEED A TRICK BILLET ALUMINUM MOUNT FOR YOUR IPHONE 5 ON YOUR POLARIS RZR? WELL I DID, SO WE MADE THIS 6061 BILLET ALUMINUM CLAMP ON IPHONE MOUNT. USING A RAM MOUNT AND OUR BILLET CLAMP AND BACKING PLATE THIS WILL MOUNT TO THE STEERING COLUMN YOUR POLARIS RZR 800, RZR 570, RZR-S, RZR-XP, RZR-4 OR RZR-XP4. WILL NOT FIT AN IPHONE 4 OR 4S WHILE USING A CASE. PART COMES IN A MACHINED FINISH AS SHOWN. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR iPod NANO 1ST GEN BILLET STEERING WHEEL MOUNT
  2. $79.95
  3. Add to Cart
  4. DO YOU NEED A TRICK BILLET ALUMINUM MOUNT FOR YOUR 1ST GEN iPod NANO ON YOUR POLARIS RZR? WELL I DID, SO WE MADE THIS 6061 BILLET ALUMINUM CLAMP ON IPHONE MOUNT. USING A RAM MOUNT AND OUR BILLET CLAMP AND BACKING PLATE THIS WILL MOUNT TO THE STEERING COLUMN YOUR POLARIS RZR 800, RZR 570, RZR-S, RZR-XP, RZR-4 OR RZR-XP4. WILL NOT FIT AN IPHONE 4 OR 4S WHILE USING A CASE. PART COMES IN A MACHINED FINISH AS SHOWN. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR iPod NANO 3RD GEN BILLET STEERING WHEEL MOUNT
  2. $79.95
  3. Add to Cart
  4. DO YOU NEED A TRICK BILLET ALUMINUM MOUNT FOR YOUR 3RD GEN iPod NANO ON YOUR POLARIS RZR? WELL I DID, SO WE MADE THIS 6061 BILLET ALUMINUM CLAMP ON IPHONE MOUNT. USING A RAM MOUNT AND OUR BILLET CLAMP AND BACKING PLATE THIS WILL MOUNT TO THE STEERING COLUMN YOUR POLARIS RZR 800, RZR 570, RZR-S, RZR-XP, RZR-4 OR RZR-XP4. WILL NOT FIT AN IPHONE 4 OR 4S WHILE USING A CASE. PART COMES IN A MACHINED FINISH AS SHOWN. Learn More
  1. Add to Wishlist
Discussion Starter #15
  1. UTV INC POLARIS RZR BILLET ALUMINUM STEERING WHEEL CENTER CAP
  2. $34.95
  3. Add to Cart
  4. MACHINED IN HOUSE FROM 6061 T6 BILLET ALUMINUM THESE REPLACEMENT CENTER CAPS FOR YOUR POLARIS RZR STEERING WHEEL ARE SURE TO ADD SOME POP TO THE CENTER OF YOUR MACHINE. CHOOSE FROM A VARIETY OF ANODIZED COLORS OR POLISHED BILLET ALUMINUM FINISH. RED, BLUE, BLACK AND POLISHED ARE AVAILABLE BELOW. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET CUP HOLDERS - PAIR
  2. $99.95
  3. Add to Cart
  4. UTV INC BILLET CUP HOLDERS - PAIR. THIS WILL REQUIRE YOU TO CUT OUT THE OEM CUP HOLDERS IF YOU HAVE A GEN 2 OR ABOVE. GEN 1 WILL SLIDE OUT, GEN 2 AND ABOVE YOU WILL HAVE TO CUT OUT. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET GAS CAP - BLACK ANODIZED
  2. $49.95
  3. Add to Cart
  4. UTV INC POLARIS RZR BILLET GAS CAP - BLACK ANODIZED
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET GAS CAP - POLISHED
  2. $49.95
  3. Add to Cart
  4. UTV INC POLARIS RZR BILLET GAS CAP - POLISHED
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET NECK SLOTS HARNESS INSERT OEM SEATS
  2. $159.95
  3. Add to Cart
  4. NOW YOU CAN ADD A 2" OR 3" Y STYLE HARNESS TO YOUR RZR USING THESE. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET SHIFTER ARM AND BLACK SHIFT HANDLE COMBO
  2. $124.95
  3. Add to Cart
  4. UTV INC POLARIS RZR BILLET SHIFTER ARM AND BLACK SHIFT HANDLE COMBO Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET SHIFTER ARM AND POLISHED SHIFT HANDLE
  2. $124.95
  3. Add to Cart
  4. UTV INC BILLET ALUMINUM SHIFTER ARM WITH DELRIN BUSHINGS AND POLISHED SHIFT HANDLE FOR ALL POLARIS RZR MODELS Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET SPEEDO BEZEL - BLACK
  2. $44.95
  3. Add to Cart
  4. UTV INC POLARIS RZR BILLET SPEEDO BEZEL - BLACK
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET SPEEDO BEZEL - BLUE
  2. $44.95
  3. Add to Cart
  4. UTV INC POLARIS RZR BILLET SPEEDO BEZEL - BLUE Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET SPEEDO BEZEL - ORANGE
  2. $44.95
  3. Add to Cart
  4. MACHINED FROM 6061 T6 BILLET ALUMINUM AND ANODIZED ORANGE. THIS SPEEDOMETER BEZEL IS DESIGNED TO REPLACE THE OEM ONE THAT SNAPS ON AND OFF. ADD A LITTLE COLOR TO YOUR DASH AND HELP GIVE THE INSIDE OF YOUR RZR A LITTLE CUSTOM LOOK TO IT. THIS WILL FIT: POLARIS RZR 800 POLARIS RZR-4 800 POLARIS RZR 570 POLARIS RZR-XP 900 POLARIS RZR-XP-4 900 Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET SPEEDO BEZEL - POLISHED
  2. $44.95
  3. Add to Cart
  4. UTV INC POLARIS RZR BILLET SPEEDO BEZEL - POLISHED
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET SPEEDO BEZEL - RED
  2. $44.95
Add to Cart
Discussion Starter #16
  1. UTV INC POLARIS RZR & RZR-S DASH BAR W/ INTRUSION V BRACING BLK
  2. $224.95
  3. Add to Cart
  4. COMES POWDER COATED BLACK Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S DASH TRIM PLATE - BLACK
  2. $84.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S DASH TRIM PLATE - BRUSHED
  2. $84.95
  3. Add to Cart
  4. BRUSHED FINISH. BOLTS UP WITH HARDWARE INCLUDED. MUST DRILL OEM PLASTIC.
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S WATER TEMP GAUGE KIT & WIRING
  2. $109.95
  3. Add to Cart
  4. A COMPLETE KIT TO ADD A WATER TEMP GAUGE TO YOUR POLARIS RZR & RZR-S. INCLUDES: AUTO METER BLACK GUAGE, AUTO METER SENDING UNIT, UTV INC INLINE WATER TEMP HOUSING, UTV INC WIRING KIT FOR WATER TEMP GAUGE.Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S WATER TEMP GAUGE WIRING KIT
  2. $24.95
  3. Add to Cart
  4. UTV INC POLARIS RZR & RZR-S WATER TEMP GAUGE WIRING KIT Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR 14" BLACK SUEDE RED STITCHING QUICK DISCONNECT STEERING WHEEL KIT
  2. $274.95
  3. Add to Cart
  4. UTV INC IS EXCITED TO BRING YOU OUR NEWEST PRODUCT TO THE POLARIS RZR MARKET. OUR 14" NO DISH BLACK SUEDE STEERING WHEEL AND QUICK DISCONNECT STEERING WHEEL HUB. THE HUB IS MACHINED FROM 6061 T6 BILLET ALUMINUM AND ANODIZED BLACK FOR A LIFE LONG DURABLE FINISH. THE STEERING WHEEL IS A HEAVY DUTY FRAME WITH PADDING AND WRAPPED IS LUXURIOUS BLACK SUEDE TO KEEP YOUR HANDS ON THE WHEEL AT ALL TIMES. RED STITCHING ACCENTS THE WHEEL AND ADDS A LITTLE POP OF FLAVOR TO HELP BRING THE ENTIRE CAR DESIGN AND COLOR SCHEME TOGETHER. THE WHEEL IS 14" IN DIAMETER AND THE KIT IS A COMPLETE BOLT ON PART WITH NO MODIFICATIONS REQUIRED TO THE MACHINE. FITS THE 570, 800 AND 900 MODELS OF THE RZR LINE UP. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR 14" BLACK VINYL RED STITCHING QUICK DISCONNECT STEERING WHEEL KIT
  2. $274.95
  3. Add to Cart
  4. UTV INC IS EXCITED TO BRING YOU OUR NEWEST PRODUCT TO THE POLARIS RZR MARKET. OUR 14" NO DISH BLACK VINYL STEERING WHEEL AND QUICK DISCONNECT STEERING WHEEL HUB. THE HUB IS MACHINED FROM 6061 T6 BILLET ALUMINUM AND ANODIZED BLACK FOR A LIFE LONG DURABLE FINISH. THE STEERING WHEEL IS A HEAVY DUTY FRAME WITH PADDING AND WRAPPED IS COMFORTABLE BLACK VINYL TO KEEP YOUR HANDS ON THE WHEEL AT ALL TIMES. RED STITCHING ACCENTS THE WHEEL AND ADDS A LITTLE POP OF FLAVOR TO HELP BRING THE ENTIRE CAR DESIGN AND COLOR SCHEME TOGETHER. THE WHEEL IS 14" IN DIAMETER AND THE KIT IS A COMPLETE BOLT ON PART WITH NO MODIFICATIONS REQUIRED TO THE MACHINE. FITS THE 570, 800 AND 900 MODELS OF THE RZR LINE UP. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR 14" SUEDE QUICK DISCONNECT STEERING WHEEL KIT
  2. $274.95
  3. Add to Cart
  4. UTV INC IS EXCITED TO BRING YOU OUR NEWEST PRODUCT TO THE POLARIS RZR MARKET. OUR 14" NO DISH BLACK SUEDE STEERING WHEEL AND QUICK DISCONNECT STEERING WHEEL HUB. THE HUB IS MACHINED FROM 6061 T6 BILLET ALUMINUM AND ANODIZED BLACK FOR A LIFE LONG DURABLE FINISH. THE STEERING WHEEL IS A HEAVY DUTY FRAME WITH PADDING AND WRAPPED IS LUXURIOUS SUEDE TO KEEP YOUR HANDS ON THE WHEEL AT ALL TIMES. THE WHEEL IS 14" IN DIAMETER AND THE KIT IS A COMPLETE BOLT ON PART WITH NO MODIFICATIONS REQUIRED TO THE MACHINE. FITS THE 570, 800 AND 900 MODELS OF THE RZR LINE UP. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR 2.5 GALLON LOCK AND RIDE GAS CAN COMBO
  2. $89.95
  3. Add to Cart
  4. Introduces our new Polaris RZR RZRs and RZRE XP 2.5 Gallon Fuel Can and UTVinc.com Lock and Ride Fuel Can Mount with 2” Velcro Strap and will come Powder coated black it is made from .063 Aluminum and supplied with UTVinc.com Knob and Ride Mounting hardware. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR 4 XP 800 900 PARKING BRAKE KIT WORKS WITH POWER STEERING
  3. $109.95
  4. Add to Cart
  5. UTV INC POLARIS RZR PARKING BRAKE KIT - WORKS WITH POWER STEERING Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR A PILLAR LED MOUNTS - PR - BLACK
  2. $39.95
  3. Add to Cart
  4. MADE FOR THE RIGID INDUSTRIES LED DUALLY LED LIGHTS. THESE TRICK MOUNTS BRING THE LED IN THE PROPER LOCATION FOR EXCELLENT VISIBILITY. COME POWDER COATED BLACK AND ALL HARDWARE IS INCLUDED.
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR BILLET ALUMINUM KEY FOB
  2. $29.95
Add to Cart
Discussion Starter #17
  2. $224.95
  3. Add to Cart
  1. Add to Wishlist
  2. $84.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  2. $84.95
  3. Add to Cart
    Learn More
  1. Add to Wishlist
  2. $109.95
  3. Add to Cart
  1. Add to Wishlist
  2. $24.95
  3. Add to Cart
  1. Add to Wishlist
  2. $274.95
  3. Add to Cart
  1. Add to Wishlist
  2. $274.95
  3. Add to Cart
  1. Add to Wishlist
  2. $274.95
  3. Add to Cart
  1. Add to Wishlist
  2. $89.95
  3. Add to Cart
  1. Add to Wishlist
  3. $109.95
  4. Add to Cart
  1. Add to Wishlist
  2. $39.95
  3. Add to Cart
    Learn More
  1. Add to Wishlist
  2. $29.95
Add to Cart
Discussion Starter #18
  1. UTV INC POFLO RZR XP XP 4 900 K&N INTAKE SYSTEM
  2. $379.95
  3. Add to Cart
  4. POFLO DESIGNED FOR THE RZR XP 900 MOTORS. LARGER BILLET AIR HORNS FOR INCREASES AIR FLOW AND VOLUME BY LARGER FILTER. CUSTOM MADE LARGE 5 LAYER K&N INTAKE FILTER WITH OUTWEAR. SUPPORT BRACKET FOR FILTERS IS INCLUDED. BILLET BREATHER VENT. COMBINED WITH CAMS, EXHAUST AND TUNING YOU WILL PACK A PUNCH IN YOUR 900 MOTOR! Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RANGER RZR & RZR-S PISTOL GRIP SHIFTER KNOB BLK
  2. $40.95
  3. Add to Cart
  4. UTV INC POLARIS RANGER RZR & RZR-S PISTOL GRIP SHIFTER KNOB BLK Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR RED ANODIZED BILLET ALUMINUM GAS CAP
  2. $49.95
  3. Add to Cart
  4. RED ANODIZED BILLET ALUMINUM GAS CAP FOR THE POLARIS RZR MODELS. ANODIZED THEN RE MACHINED FOR THE HIGHLIGHTED ACCENTS. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S 1 GAUGE DASH TRIM PLATE - BLACK
  3. $84.95
  4. Add to Cart
  5. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S 1 GAUGE DASH TRIM PLATE - BRUSHED
  2. $84.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S 2 GAUGE DASH TRIM PLATE - BLACK
  2. $84.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S 2 GAUGE DASH TRIM PLATE - BRUSHED
  2. $84.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S 3 GAUGE DASH TRIM PLATE - BLACK
  2. $84.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S 3 GAUGE DASH TRIM PLATE - BRUSHED
  2. $84.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S BILLET WHIP MOUNT FOR BED
  2. $19.49
  3. Add to Cart
  4. MOUNTS USUING UTV INC BILLET LOCK AND RIDE OR UTV INC KNOB AND RIDE MOUNTING SYSTEMS ON THE BED OF THE POLARIS RZR Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S CLAMP ON DASH BAR
  2. $134.95
  3. Add to Cart
  4. USE THIS CLAMP ON DASH BAR TO ADD STRENGTH TO YOUR OEM ROLL CAGE TO HELP PREVENT THE CAGE FROM BENDING IN THE EVENT OF A ROLL OVER. ALSO CAN ADD TABS FOR LIGHTS AS SHOWN. PRICE IS FOR THE BAR POWEDER COATED WITH NO LIGHT TABS.
    Learn More
  1. Add to Wishlist
  1. UTV INC POLARIS RZR & RZR-S CLAMP ON DASH BAR W/ LIGHT TABS
  2. $149.95
  3. Add to Cart
  4. IF YOU THOUGHT YOU WERE COOL BEFORE... NOW YOU CAN BE EVEN COOLER. THE UTV INC POLARIS RZR DASH BAR WITH LIGHT TABS IS THE COOLEST THING YOU COULD BUY FOR YOUR POLARIS RZR OR RZR-S. COMES IN BLACK POWDER COATED FINISH TO MATCH THE OEM CAGE.
    Learn More
  1. Add to Wishlist
Discussion Starter #19
  1. UTV INC BLUE ANODIZED POLARIS RZR BILLET ALUMINUM CUP HOLDERS
  2. $99.95
  3. Add to Cart
  4. UTV INC BLUE ANODIZED BILLET CUP HOLDERS - PAIR. THIS WILL REQUIRE YOU TO CUT OUT THE OEM CUP HOLDERS IF YOU HAVE A GEN 2 OR ABOVE. GEN 1 WILL SLIDE OUT, GEN 2 AND ABOVE YOU WILL HAVE TO CUT OUT. Learn More
  1. Add to Wishlist
  1. UTV INC BLUE LED LIGHTED ON OFF ROCKER SWITCH
  2. $11.95
  3. Add to Cart
  4. 21 AMP LED LIGHT LIGHTED ON OFF ROCKER SWITCH. FITS RZR DASH PLATE, RHINO DASH PLATE, CAN AM COMMANDER DASH AND WILDCAT DASH Learn More
  1. Add to Wishlist
  1. UTV INC CHROME 6 LED LICENSE PLATE FRAME
  3. $29.95
  4. Add to Cart
  5. UTV INC CHROME 6 LED LICENSE PLATE FRAME Learn More
  1. Add to Wishlist
  1. UTV INC DUALLY D2 BACK LIT LED SWITCH
  2. $17.95
  3. Add to Cart
  1. Add to Wishlist
  1. UTV INC EMERGENCY TIRE INFLATION & REPAIR KIT
  3. $169.95
  4. Add to Cart
  5. UTV INC IS PROUD TO BRING YOUR OUR EMERGENCY UTV TIRE INFLATION & REPAIR KIT. INCLUDES: 20 OZ CO2 TANK COILED HOSE TO PREVENT TANGLING AND EASE OF USE QUICK DISCONNECT FITTING FOR EASY INSTALLATION AND REMOVAL OF HOSE FROM TANK BILLET ALUMINUM VALVE TO OPEN TO AND CLOSE THE BOTTLE QUICK DISCONNECT VALVE STEM HOLDER FOR EASY 1 HAND OPERATION TIRE PLUG KIT LOW PRESSURE TIRE GAUGE BLACK CANVAS BAG TO HOLD EVERYTHING IN PLACE Learn More
  1. Add to Wishlist
  1. UTV INC FIBER OPTIC WHIP FLAG MOUNTING KIT
  2. $8.95
  3. Add to Cart
  4. UTV INC FIBER OPTIC WHIP FLAG MOUNTING KIT Learn More
  1. Add to Wishlist
  1. UTV INC FLAG - DRIVER SIDE
  2. $18.95
  3. Add to Cart
  4. UTV INC FLAG 12" X 24" - DRIVER SIDE Learn More
  1. Add to Wishlist
  1. UTV INC FLAG - PASSANGER SIDE
  2. $18.95
  3. Add to Cart
  4. UTV INC FLAG 12" X 24" - PASSANGER SIDE Learn More
  1. Add to Wishlist
  1. UTV INC GREEN 3" H STYLE 4 PT HARNESS WITH SEWN IN PADS, STERNUM STRAP & SEWN TOGETHER
  2. $109.95
  3. $99.95
  4. Add to Cart
  5. GREEN 3" H STYLE (INDIVIDUAL SHOULDER BELTS) HARNESSES WITH THE LAP BELTS SEWN INTO THE SHOULDER BELTS (EASIER USE) WITH SEWN IN PADS AND STERNUM STRAP CLIP Learn More
  1. Add to Wishlist
  1. UTV INC HORIZONTAL GO PRO MOUNT SILVER BLACK 1¼" 1½" 1¾" 2"
  2. $49.95
  3. Add to Cart
  4. UTV INC HORIZONTAL GO PRO MOUNT. AVAILABLE IN SILVER OR BLACK. SIZES AVAILABLE: 1¼" 1½" 1¾" 2" Learn More
  1. Add to Wishlist
  1. UTV INC KNOB & RIDE FOR RZR LOCK & RIDE HOLES
  2. $9.95
  3. Add to Cart
  4. Learn More
  1. Add to Wishlist
  1. UTV INC MULTI ANGLE GO PRO CLAMP ON MOUNT
  2. $56.95
  3. Add to Cart
  4. UTV INC MULTI ANGLE GO PRO CLAMP ON MOUNT - PLEASE SPECIFY WHAT COLOR MOUNT AND WHAT SIZE TUBING YOU WANT BELOW. Learn More
  1. Add to Wishlist
  1. UTV INC ORANGE ANODIZED POLARIS RZR BILLET ALUMINUM CUP HOLDERS
  2. $99.95
  3. Add to Cart
  4. UTV INC ORANGE ANODIZED BILLET CUP HOLDERS - PAIR. THIS WILL REQUIRE YOU TO CUT OUT THE OEM CUP HOLDERS IF YOU HAVE A GEN 2 OR ABOVE. GEN 1 WILL SLIDE OUT, GEN 2 AND ABOVE YOU WILL HAVE TO CUT OUT. Learn More
Discussion Starter #20
  1. UTV INC BLACK 2" H STYLE PADDED SEWN TOGETHER WITH STERNUM CLIP HARNESS RESTRAINT SYSTEM
  2. $104.95
  3. $99.95
  4. Add to Cart
  5. UTV INC IS HAPPY TO RELEASE OUR NEWEST HARNESS TO OUR LINE UP. THESE BLACK 2" H STYLE PADDED HARNESSES FEATURE A SEWN TOGETHER SHOULDER AND LAP BELT FOR EASIER ENTRY AND EXIT OF THE VEHICLE WITH ONLY HAVING 1 BUCKLE. THE STERNUM CLIP IN THE MIDDLE IS GREAT FOR USE ON STOCK SEATS OR SEATS THAT THE HARNESS WILL GO OVER THE SHOULDER BOLSTERS AND NOT THROUGH. THIS WILL ELIMINATE THE SHOULDER BELTS SLIDING OFF YOUR SHOULDERS ONCE BUCKLED IN. OUR NEWEST PADS ARE NOW LONGER AND SOFTER TO ALLOW AN EVEN MORE COMFORTABLE RIDING EXPERIENCE WHEN HARNESSED INTO THE MACHINE. ALSO, WE HAVE CHANGED FROM THE TRADITIONAL SILVER HARDWARE TO NEW ALL BLACK HARDWARE. REALLY MAKES THESE HARNESSES LOOK A LOT BETTER! SHOULDER BELTS FEATURE BOTH A MOUNTING TAB OR WRAP AROUND ATTACHMENT STYLE. Learn More
  1. Add to Wishlist
  1. UTV INC BLACK 2011 POLARIS RZR RZR-S RZR-4 ALUMINUM GRILL - SLOTTED W/ LOGO
  2. $59.95
  3. Add to Cart
  4. UTV INC BLACK 2011 POLARIS RZR RZR-S RZR-4 ALUMINUM GRILL - SLOTTED W/ LOGO Learn More
  1. Add to Wishlist
  1. UTV INC BLACK 2011 POLARIS RZR-XP & 570 GRILL - SLOTTED W/ LOGO DESIGN
  2. $59.95
  3. Add to Cart
  4. UTV INC BLACK 2011 POLARIS RZR-XP & 570 GRILL - SLOTTED W/ LOGO DESIGN Learn More
  1. Add to Wishlist
  1. UTV INC BLACK 3" Y STYLE 4 PT HARNESS WITH SEWN IN PADS & SEWN TOGETHER
  2. $109.95
  3. Add to Cart
  4. UTV INC BLACK 3" Y STYLE 4 PT HARNESS WITH SEWN IN PADS & SEWN TOGETHER SHOULDER AND LAP BELTS Learn More
  1. Add to Wishlist
  1. UTV INC BLACK 6 LED LICENSE PLATE FRAME
  2. $29.95
  3. Add to Cart
  4. UTV INC BLACK 6 LED LICENSE PLATE FRAME Learn More
  1. Add to Wishlist
  1. UTV INC BLACK ANODIZED CLAMP ON UNIVERSAL LED / HID LIGHT MOUNT
  2. $34.95
  3. Add to Cart
  4. UTV INC BLACK ANODIZED CLAMP ON UNIVERSAL LED / HID LIGHT MOUNT Learn More
  1. Add to Wishlist
  1. UTV INC BLACK BILLET CLAMP ON LED LIGHT BAR MOUNT 1½"
  2. $34.95
  3. Add to Cart
  4. UTV INC BLACK BILLET CLAMP ON LED LIGHT BAR MOUNT 1½" Learn More
  1. Add to Wishlist
  1. UTV INC BLACK BILLET CLAMP ON LED LIGHT BAR MOUNT 1¾"
  2. $34.95
  3. Add to Cart
  4. UTV INC BLACK BILLET CLAMP ON LED LIGHT BAR MOUNT 1¾" Learn More
  1. Add to Wishlist
  1. UTV INC BLACK BILLET CLAMP ON RIGID LED DUALLY & D2 LIGHT BAR MOUNTS
  2. $59.95
  3. Add to Cart
  4. THESE AWESOME CLAMPS WILL FIT ANY 1.25, 1.5, 1.75 OR 2 INCH TUBE AND ALLOW YOU TO MOUNT A RIGID DUALLY OR RIGID DUALLY D2 LED LIGHT BAR TO THEM. MACHINED FROM 6061 T6 BILLET ALUMINUM AND ANODIZED BLACK TO MATCH MOST OEM CAGES OR CHASSIS. Learn More
  1. Add to Wishlist
  1. UTV INC BLUE 3" H STYLE 4 PT HARNESS WITH SEWN IN PADS, STERNUM STRAP & SEWN TOGETHER
  2. $109.95
  3. $99.95
Add to Cart
1 - 20 of 31 Posts
