im seeing alot of discussion on O2 wide band sensors... i have a 2010 s and the only oxygen sensor i see is on the intake.. is this a different sensor..? should i upgrade it..?.
Your RZR don't have oxygen sensor, what you see is a map sensor.im seeing alot of discussion on O2 wide band sensors... i have a 2010 s and the only oxygen sensor i see is on the intake.. is this a different sensor..? should i upgrade it..?.
I think technically it is a tbap sensor. Temp and barometric pressure.Your RZR don't have oxygen sensor, what you see is a map sensor.im seeing alot of discussion on O2 wide band sensors... i have a 2010 s and the only oxygen sensor i see is on the intake.. is this a different sensor..? should i upgrade it..?.
milos
