Description
This high quality T-BAP repair harness typically fixes Polaris engine codes:
Blink code 41
Blink code 45
Blink code 46
SPN 102, FMI 3, 4, 2
SPN 105, FMI 3, 4
Some symptoms of a bad T-Bap harness are engine will run poorly, no power, poor idle and engine miss. This will be very noticeable when riding in changing elevations.
https://otbpowersports.com/product/t-bap-wiring-repair-harness/
Description
This harness will fit all Polaris EFI 700cc – 1000cc 550cc 570cc machines with the exception of the RZR 900.
This high quality repair harness typically fixes Polaris engine codes:
SPN 634 FMI 7,4,3,5
SPN 520270 FMI 4,3,5
SPN 520269, FMI 4,3,5
SPN 520268 FMI 4,3,5
Some symptoms of a bad Idle air control motor wiring harness are engine will not stay idling, idle will be too high or to low. Engine will die when letting off the gas.
This harness fits All 500cc, 550cc, 570cc, and 850cc – 1000cc machines as well as some 800cc and up Rangers.
https://otbpowersports.com/product/idle-air-control-motor-wiring-repair-harness/
Description
This quality throttle position sensor repair harness typically fixes:
Polaris blink code 22, and fault code SPN 51
Some symptoms of a bad TPS wiring harness are engine will not idle, or have hard time revving.
This harness works on all 500cc, 550cc, 570cc machines and some 700cc-800cc Rangers.
https://otbpowersports.com/product/tps-sensor-repair-harness/
Description
This high quality replacement ignition switch repair harness and ignition switch fixes issues with melted ignition switch connectors from overloaded or shorted connections. This 7 inch long harness has all 6 positions loaded and comes with sealed crimp splices. The ignition switches are imported, however we take each one apart and inspect quality, and add dielectric grease to the contacts of each one and test them before they go out.
Some symptoms of a bad ignition switch and or switch wiring are:
Vehicle will not power on when key is turned. ( Always check that the battery is good and fully charged )
Vehicle will not crank or only crank some of the time. ( Always check starter solenoid and starter )
Vehicle will randomly quit running as if the Ignition switch was turned off. ( No Instrument Cluster, No Headlights, No Crank)
https://otbpowersports.com/product/ignition-switch-and-repair-harness-combo/
Description
This high quality replacement ignition switch repair harness fixes issues with melted ignition switch connectors from overloaded or shorted connections. This 7 inch long harness has all 6 positions loaded and comes with sealed crimp splices.
https://otbpowersports.com/product/ignition-switch-repair-harness/
Description
This high quality wiring harness typically fixes Polaris engine codes:
SPN 651 FMI 3,4,5
SPN 652 FMI 3,4,5
Some symptoms of a fuel injector wiring harness is engine will miss and run on one cylinder and engine will have loss of power. These conditions may be intermittent.
This harness fits all twin cylinder machines 850cc-1000cc for all years.
https://otbpowersports.com/product/fuel-injector-wiring-repair-harness/
Description
SPN 651 FMI 3,4,5
SPN 652 FMI 3,4,5
Blink Code 51
Blink Code 52
This harness fits the 1000 RZR Turbo machines as well as Sportsman and Ranger 700cc machines. Note: On 700cc machines the factory connector is glued on to the injector so the connector must be broken apart and removed before this new harness can be installed.
https://otbpowersports.com/product/fuel-injector-wiring-repair-harness-rzr-turbo/
Description
SPN 105, FMI 3, 4
SPN 1127, FMI 0, 3, 4, 31
SPN 2629, FMI 3, 4
This harness will fit the Polaris 1000 RZR Turbo. The Polaris 1000 RZR Turbo uses 2 of these sensors so you may need to purchase 2 of them if you are not sure which one is bad. One sensor is located on the end of the throttle body and the other is on top of the intake/intercooler assembly.
https://otbpowersports.com/product/t-bap-wiring-repair-harness-turbo/
Description
This high quality pressure sensor repair harness typically fixes:
blink codes: 45, 46.
Some symptoms of a bad pressure sensor harness are engine will run poorly, no power, poor idle, or engine misfire.
This harness fits 500cc EFI machines.
https://otbpowersports.com/product/pressure-sensor-repair-harness/
Description
This high quality repair harness typically fixes Polaris codes:
Blink Code 41
Some symptoms of a bad intake air temperature sensor harness is engine will run poorly when the vehicle gets up to operating temperature.
https://otbpowersports.com/product/intake-air-temp-sensor-repair-harness-500cc/
Description
Blink Code 42
SPN 110, FMI 3, 4, 16, 0
A symptom of a bad coolant temp sensor wiring harness is the engine cooling fan will run even when the engine is cold.
https://otbpowersports.com/product/coolant-temp-sensor-harness-500cc/
Description
This high quality wiring repair harness typically fixes Polaris engine codes:
Blink Code 42
SPN 110 FMI 3, 4, 16, 0
Some symptoms of a bad cooling fan wiring harness are the engine cooling fan will run all the time even when engine is cold and or never turn on when hot.
All Twin Cylinder EFI ATVs / UTVs 2004.5 – 2014.
https://otbpowersports.com/product/coolant-temperature-harness/
Description
This speed sensor repair harness typically fixes Polaris engine code:
SPN 84 FMI 2
Some symptoms of a bad speed sensor repair harness is speedometer will intermittently not function or no functionality may be present.
this fits all XP Series ATVs and RZR. Model Years 2009-2014.
https://otbpowersports.com/product/otb-pol-spd-09-14/
Description
This high quality wiring harness typically fixes Polaris codes:
SPN 636 FMI 8, 2
Some symptoms of a bad crankshaft position sensor harness are the engine will intermittently stall out and may or may not restart.
This harness fits 700cc – 1000cc machines that have the purple connector seal.
https://otbpowersports.com/product/crankshaft-position-sensor-harness/
Description
SPN 636 FMI 8, 2
https://otbpowersports.com/product/crankshaft-position-sensor-harness-2/
Description
This high quality stator repair harness replaces the factory connector that has been prone to failure by melting. This replacement harness uses 10AWG wire and can better handle the current.
This harness is rated at 42 Amps and will repair burnt stator wiring on all Polaris models and also may be used for any other vehicle that uses a 3 wire stator connection.
Some symptoms of bad stator wiring is low battery voltage, dim headlights and or dead battery
https://otbpowersports.com/product/stator-connector-repair-kit/
Description
This harness is required when replacing 4 wire stator connections and this harness is meant to accompany the 3 wire stator repair harness PN: OTB-POL-STA-14-18. https://otbpowersports.com/product/stator-connector-repair-kit/
https://otbpowersports.com/product/stator-connector-repair-kit-additional-wire/
