1 - 2 of 2 Posts
Description
This high quality repair harness kit replaces melted voltage regulator vehicle side wiring on 900cc Polaris RZR and Ranger machines. This kit is typically used after a voltage regulator has failed and melted the vehicle voltage regulator connectors.
https://otbpowersports.com/product/voltage-regulator-repair-harness-kit-for-polaris-900cc-vehicles/
Description
This high quality 20 inch long handlebar control switch repair harness features mil spec flexible wire that won’t break over time with handle bar movement. Polaris ATV’s use 3 of these harnesses. Two of them are on the left handle bar control and one is on the right handle bar control. We suggest replacing all 3 of them as a set. Some symptoms of bad handle bar control wiring are:
Vehicle loses all power when driving over rough terrain
Vehicle loses all power when turning handle bars
Headlights intermittently turn on and off when turning handle bars or driving over rough terrain
Reverse override switch does not function properly
Throttle safety switch limits vehicle speed
Codes SPN 520194 FMI 7, FMI 2, FMI 3 May be present
AWD may be intermittent or not function
Note: This harness comes complete with all 6 wires populated in the connector. Some machines use 3-6 wires depending on the model of the machine. When installing this repair harness simply leave any unused wires disconnected.
https://otbpowersports.com/product/polaris-handle-bar-control-switch-repair-harness/
Description
This high quality repair harness typically fixes engine code:
SPN 523 FMI 4
The symptom of a bad gear position wiring harness is the gear indicator on the instrument cluster will be dashed out.
This harness fits all ATV’s and UTV’s 2004-2016 with 6 pin gear position sensors.
https://otbpowersports.com/product/gear-position-sensor-repair-harness/
Description
This wiring harness will typically fix Polaris engine code:
SPN 1269 FMI 3
Some symptoms of a bad ignition coil harness are engine will have a miss, no power, engine will be only running on one cylinder. Engine will run poorly intermittently. Engine will intermittently die out or not start.
This fits All Twin Cylinder EFI ATVs / UTVs 2004.5 — 2014.
https://otbpowersports.com/product/otb-pol-ign-05-14/
Description
This wiring repair harness fixes issues with corroded and broken brake light switch wiring on 2014-Current Polaris RZR’s. Some symptoms of a bad brake light switch is the vehicle will have no brake lights when stepping on brake pedal and will also the machine will only start when in park or neutral.
https://otbpowersports.com/product/polaris-rzr-brake-switch-repair-harness/
Description
SPN 520342 FMI 3, 4
SPN 520344 FMI 4
SPN 520209 FMI 4
SPN 3056 FMI 2, 3, 4
Some symptoms of a bad O2 sensor wiring harness is a check engine light and the machine may run rich or lean causing poor idle, and or lean miss during acceleration.
This fits All 2015-Current Polaris RZR’s, Rangers, and Generals.
https://otbpowersports.com/product/oxygen-sensor-repair-harness/
Description
This high quality repair harness typically fixes Polaris codes:
Blink Code 56
SPN 1347 FMI 3,4,5
Some symptoms of a bad fuel pump wiring harness are the engine may quit intermittently, the fuel pump will not operate, and the fuel gauge may not read correctly. Also check fuel pump and sending unit to ensure they are in working order.
This harness fits All XP twin cylinder machines 850cc-1000cc 2009-current.
https://otbpowersports.com/product/fuel-pump-wiring-repair-harness/
Description
This high quality wiring repair harness will typically fix Polaris headlight connectors that have melted from excessive heat. This repair harness will also replace tail light connectors on the Polaris RZR.
Some features of this harness are:
Heavier gauge high strand count wire 18 AWG vs. 20 AWG OEM.
Easy Installation
https://otbpowersports.com/product/headlight-repair-wiring-harness/
Description
This high quality bus bar accessory wiring adapter is used on the 2018 Polaris RS1 machines. This adapter harness plugs into the factory bus bar and allows you to provide power to light bars, radios, and other accessories. This harness comes in your choice of lengths 1-6 Feet. The connections are as follows:
Red = Constant Battery 12+ Power
Orange = Switched 12V+ Ignition Power
Black = Vehicle Ground
https://otbpowersports.com/product/polaris-bus-bar-accessory-wiring-adapter/
Description
This high quality 10 gauge wired adapter harness replaces melted or broken stator to regulator adapter harnesses. The symptom of a bad regulator harness is melted or broken wires. This harness is used on RZR 900 and 1000.
https://otbpowersports.com/product/polaris-regulator-to-stator-replacement-harness/
Description
The rugged shop environment can sometimes take its toll on the Check Tech diagnostic tool wiring harness. This harness is a replacement wiring harness for the Check Tech diagnostic tool for Polaris.
https://otbpowersports.com/product/replacement-check-tech-wiring-harness/
Description
SPN 520342 FMI 3, 4
SPN 520344 FMI 4
SPN 520209 FMI 4
This fits 2017-Current Polaris General and some Ranger platforms
https://otbpowersports.com/product/oxygen-sensor-repair-harness-for-polaris-general/
Description
This high quality replacement 14 pin ECM repair harness fixes melted wiring on 2005-2009 Polaris Rangers. When the ECM in a Polaris Ranger fails it can sometimes internally short and this melts the wiring and connector. (Note: If your connector is melted chances are you will need to replace the ECM along with this harness. Failure to do so will lead to the connector melting down again due to the failed ECM.)
https://otbpowersports.com/product/polaris-500cc-ranger-ecm-repair-harness/
Description
This high quality bus bar accessory kit is all that’s needed to install light bars, fans, radios, and any other switched accessories in your 2017-Current Polaris RZR and General. This kit features:
30 Amp Capacity
Relay Switched Power
Fused
Lighted Rocker Switch Ready
Ignition Switch Controlled ( No dead battery if you accidentally leave an accessory on )
Lightning Fast Installation of Accessories
Here is how simple it is to install an accessory on your machine when using this kit.
Connect RED and BLACK wires to your accessory. RED is 12V+ and BLACK is ground.
Plug in YELLOW wire to the center(common) terminal of the rocker switch. Plug in BLUE wire to the rocker switch light ground if equipped. Plug in RED wire to the normally open contact of the rocker switch
Plug in the main harness connector into the bus bar.
Fasten the relay with a screw or zip tie.
Install a mini blade fuse of the current rating of your accessory.
Done!
Includes:
Complete Switch Harness
Relay
Note: SWITCH AND FUSE ARE NOT INCLUDED WITH THIS KIT. YOU WILL NEED TO PROVIDE THESE AS THEY ARE SPECIFIC TO YOUR APPLICATION!
https://otbpowersports.com/product/polaris-bus-bar-accessory-kit/
Description
This high quality instrument cluster repair harness fixes broken or melted wires connecting to the instrument cluster. All wires on this connector are included to be compatible with all cluster pin outs. This harness is compatible with Polaris instrument clusters that have a 16 pin connector.
https://otbpowersports.com/product/polaris-instrument-cluster-repair-harness/
Description
This high quality power steering power repair harness fixes broken or melted wiring on all Polaris models using the Globe Motors brand power steering module. Some symptoms of failed power steering power wires are: No power steering, Intermittent power steering.
https://otbpowersports.com/product/polaris-power-steering-power-repair-harness/
Description
This high quality power steering motor repair harness upgrades and fixes broken wires on all Polaris vehicles with electric power steering (EPS). Some symptoms of a broken wiring harness on the EPS module is power steering will work briefly when first turning the ignition on. Power steering intermittently works while operating the machine.
https://otbpowersports.com/product/polaris-power-steering-repair-harness/
Description
This high quality throttle body motor repair harness upgrades and fixes broken Polaris drive by wire throttle body motor wiring. Some symptoms of broken throttle body wiring are: Engine will shutdown, engine idles and will not rev. Engine fault codes may include:
SPN 520277, FMI 2, 3, 4, 8, 31
SPN 520278, FMI 31
SPN 520279, FMI 31
SPN 520280, FMI 31
SPN 520281, FMI 31
SPN 520282, FMI 31
SPN 520283, FMI 2, 3, 4
SPN 520284, FMI 31
https://otbpowersports.com/product/polaris-rzr-turbo-throttle-body-motor-repair-harness/
Description
SPN 520278, FMI 31
SPN 520279, FMI 31
SPN 520280, FMI 31
SPN 520281, FMI 31
SPN 520282, FMI 31
SPN 520284, FMI 31
https://otbpowersports.com/product/polaris-throttle-body-motor-repair-harness/
Do you alloffer a repair harness for the ignition coil (3 wire with plug) for a 17’ XP Turbo? Blowoff valve was rubbing against mine and broke the wire.
1 - 2 of 2 Posts
