Call me a Mope
Which where I come from is a cross between a Moron and a Dope.
But did anyone have the same problem as me trying to get the allen screws and the nuts off of their roll cage.
I could not fit a socket on to the nylon nuts because the sleeve is to close and I broke the dam allen wrench trying to crack the nut.
I was trying to run a stereo wire through the piping inside the roll cage from the top where I mounted the stereo on the underside of the roof and go down the piping to the hood.
The two bolts holding the roll cage together at the bottom right side where the piping meets the hood were obstructing the snake to send the wire through to the stereo.
I figured I would back them out and snake the wire through where I drilled the hole to go under the dash but for the life of me I could not get the dam allens outta the nylon bolts even with 250 llbs of force from my body.
The only thing I could figure after I broke the allen wrench was they musta used an air gun.
Am I the only one that has run in to this crap?
