Okay Rzr experts--Here's a couple of questions.
Installed an Opti 600 filter and in the process removed the throttle body, cleaned due to the dirt and grime ingested by the stock filter and re-installed.
Fired up the machine, ran rough--seems to be due to fuel however it acts like it is running lean, high engine temp, back firing & sputtering as well as stalling out at low idle.
--Could the throtle postioner (black housing that operates butterfly) be off alignment and cause this?
I removed a portion of the housing for clearance of the sensor, removed the sensor from the port--ran the same, disconnected sensor and ran the same?
I would not assume bad fuel would cause a lean condition--only run poorly but the heat from a run around the neighbor hood was more than any hard run at a track or trail.
Any thoughts would be appreciated?
