Did you have to pull the tranny to do this ? also what did you use to reseal it ?I recently had to reseal the transfer case cover cuz of leak. Check your fluid levels and that may point u in the right direction...good luck
Dealer had to pull my tranny split apart the transfercase cover and reglue itDid you have to pull the tranny to do this ? also what did you use to reseal it ?I recently had to reseal the transfer case cover cuz of leak. Check your fluid levels and that may point u in the right direction...good luck
any idea what they used for sealent ?Dealer had to pull my tranny split apart the transfercase cover and reglue itDid you have to pull the tranny to do this ? also what did you use to reseal it ?I recently had to reseal the transfer case cover cuz of leak. Check your fluid levels and that may point u in the right direction...good luck
SENT FROM MY DROID
