1 - 4 of 4 Posts
Hi All,
seem to recall a sticky somewhere about oil equivalants for the polaris stuff. Can't seem to find it.
If anyone can help, that would be great!!
We have a Fuchs rep here,wanting some details.
Thanks heaps.
Smitty
Here are some I found:
Front diff:
ATF | Mobil 1™ Synthetic ATF
Rear diff\trans:
Gear Lube | Mobil 1™ Synthetic Gear Lube LS 75W-90
Engine:
0W-40 Synthetic Oil | Mobil 1™ 0W-40
Oil Filter: M1-110
Oil Filters | Mobil 1™ Motorcycle
Chassis grease:
Synthetic Grease | Mobil 1™
another:
If you want the best oil that meets/exceeds Polaris oil specs for zinc/phosphorous, that most all other oils don't meet, and you don't mind spending $10-11 a qt...
Mobil 1 Racing 0W-50
Phosphorus Level, PPM1750
Zinc Level, PPM1850
another for front drive unit "diff":
Mobil 424 which is what Hilliard Mfg puts in the Front Diffs when Polaris gets them. Hilliard Mfg builds the Front Diffs for Polaris.
Hope this helps.
Front diff:
Rear diff\trans:
Engine:
Oil Filter: M1-110
Chassis grease:
another:
Zinc Level, PPM1850
Hope this helps.
Hey you Cajun ....... You stoled my post :rollfinger: ... J\K :)
1 - 4 of 4 Posts
