1 - 4 of 4 Posts
Me and my buddy both changed oil in our 900 xp's we both drained all oil both plugs pulled new filters and added3.5 quarts ps4 and both read way over full when u check oil after letting run for a few seconds. What's up anyone else
Mine did the same thing. There's another thread I remember reading awhile back about this. Dry sump oil systems are weird like that. It's always better to have a little too much than not enough
Don't feel picked-on; the 2012 800's are the same way: when you put in the specified 2 qts. of oil, the level always reads high on the dipstick. After tracking it carefully over a period of time, and several oil changes, I finally drilled a new, small hole in the dipstick, corresponding to the correct "full" level. FWIW.........
Cheers
Mine usually turns out perfect, but I let it drain for 30 minutes while I work on other stuff.
Sent from my SGH-T989 using Tapatalk 2
1 - 4 of 4 Posts
