1 - 10 of 10 Posts
11 and 12's are 3.5qts. 13's are 2.5qts according to the XP oil change kit in the 13 parts catalog.
I run 4 quarts even in mine. I don't see any harm in doing so.
Wish i wasn't at work
My 12 holds 3.5 quarts. I would say where the sump isnt there anymore, theres no need for the extra oil to keep the sump full. That would be my guess. If it calls for 2.5 then use that and check it, if its at the full mark then you shouldnt have an issue.
Wish i could be riding more :-(
The 11 and 12 dry sump has oil lines from the sump pump to tank and from the tank to pressure pump. These lines contain oil, prob a quart
I have 2011 xp 900 I put in 4 qts plus pint of lucas for cold starts,no problems with blowing out oil or leaks yes it show,s over full but no problems.
1 - 10 of 10 Posts
