No power on batt side of busbar
8.2K views 17 replies 3 participants last post by  GRegT27
How can I check the inline fuse on the battery side of the busbar? I have no power in that side but power on acc side.
Found this on PoPo accessory page. Seems to me its what you need to power up the buss bar. I could be wrong.
#15 ·
Do you have an ohm meter? disconnect the buss bar battery positive wire from battery. Make sure the meter is on and on ohms. one meter probe on batt end, other on bar end. If meter needle moves or digits show, you have continuity.
Enjoy the new ride! Lots of info here to get you familiar with it. Time to start a tool box for basic testing and repairs. For starters, learn to take the belt cover off and remove and install the belt. Also, look into what rollers are on the secondary clutch. If they are square, replace them. But that's a whole new can of worms. Have fun!
