1 - 4 of 4 Posts
New to us 08....
And just a note, we are basically mechanically challenged.
All stock minus the airfilter and shocks.
Sometimes when running with the lights on, the battery alert will start blinking. Turning the lights off for awhile helps. It's a new battery...according to prior owner.
What's happening?
The problem seems to be with the voltage regulator over heating. The newer RZRs have it relocated in front of the radiator. There is a forum member that makes a relocation kit and sells them here. Do a search and you should find it. I had installed 2 batteries and still have the same problem. Once in relocated the voltage regulator I never had another issue.
1 - 4 of 4 Posts
