1 - 8 of 8 Posts
Not sure I’ve seen anyone talk about this... Polaris updated the output hubs to seal them better from leaks.
I’ve talked about the silicone trick in this video:
After a 3 hard trips to Moab and nearly 3000 miles of use I noticed the output hubs were rather loose, and I wanted to upgrade the Sprague, armature etc anyways and I noticed the new hubs once they arrived:
Looks like a new brass style freeze plug with a rubber cover on the backside
Old Part # 3236046
New Part # 3236351
Mines been fixed 3 times under warranty, leaking again now.
Sandcraft will be getting my business now.
They have an upgraded output hub assembly?
They have a fix to prevent the leaking. Not sure exactly but I think they add some sort of "freeze plug" to prevent the leaking
Discussion Starter #7
Hmmmm... considering there is already a steel freeze plug. The updated hub looks to be brass now with the rubber seal.
I was impressed with the update and I’ve been critical of the previous idea
My '16 XPT was leaking. They replaced the seals ( my aftermarket extended warranty). I got it back and it was still leaking. This time they put a new front diff in it. I got no papework so I don't know what the part number is. It took three years for the first one to start leaking if this one last that long it will be time for a new machine
1 - 8 of 8 Posts
