Ok. Received my new turbo kit yesterday and will begin the install tomorrow. The kit has no 02 bung installed and the pictures off their site (I will post a complete review upon completion) shows the bung installed at the header collector. The system runs the Dynojet PC5 with larger injectors, and I plan to run the auto tune module, which means I need 2 bungs. One for the auto tune, one for the AFR gauge. I've seen that other kits (K&T) run a bung AFTER the turbo. I thought it had to be fairly close to the exhaust ports to maintain enough heat, but don't know. Any suggestions as to where to weld in the two bungs would be appreciated. I plan to run a Turbosmart gated controller to allow on the fly switching of the boost level and fuel maps. 7 psi for the wife and kids, 14 psi when the need for speed takes over my soul! Any knowledgable input on anything turbo would be appreciated.
Just some friendly advice ....... List all your questions on paper -- Then call where you purchased your system from and have your questions addressed.
The bung always goes post Turbo - And there is a correct way to orientate.
You don't need 2 bungs - Unless you want 2. You don't need a dash A/F gauge - Unless you want one. And if so - Using just one bung run the Wideband 2.
Don't want to run the Wideband 2 and still install just install 1 bung -- Then run the LCD-200.
Running 2 Boost levels - 14 PSI and your going to have issues .. Unless you build your motor.
Running 2 different fuel maps. Do not run a map switch.
IF you build the pressure table correctly -- One can run at various Boost levels without concern.
I suggest you download their software (1.0.6.4) -- Its FREE .... And once loaded on your computer click on the "Help" tab and read the manual. It's in alphabetical order -- Not in flowchart format so picking out the information takes a bit of time and understanding. You cannot read the manual enough !!
You will also need to install a MAP sensor. You will need to know what type to buy and how to hookup and program the software. You might also look at the new Pti version fo the PCV.
I don't mean to scare you -- But I suggest your doomed to failure unless you work with your retailer on that kit you bought.
:ride:
