1 - 19 of 19 Posts
Hey guys. Picked up my 2018 rzr xp1000 about a month ago and loving it. I do have a few questions about it. My right rear wheel is toed in pretty good at the top and was loose. I replaced the wheel bearings and seamed to tighten it up. I put ten miles on it since and noticed it’s toed in again. The wheel has no play. Is there a way to align the rear end without adjustable radius rods?
Take a picture of the bad side and let everyone have a good look. Guess is bent radius rod.
The factory radius arms aren't really very strong. I had a rock eat one of mine on the first real trail I wheeled on.
Where you from?
Sent from my LM-G710 using Tapatalk
I’m in central Indiana and the only place I’ve ridden since getting the machine is the badlands in Attica. (Only has the rzr for about a month) the bad side is the passenger side.
Something is bent, but what? I would jack it up. Remove wheels and try to measure the rods on both sides. Could take them off and lay on top of each other to compare. Simple to take off. If not that, then really look over the hub for damage.
Sure others will have more help.
Not quite as easy to diagnose but a twisted trailing arm would also be a possibility
Sent from my SM-T550 using Tapatalk
It’s hard to tell for sure, could just be the angle of the pic, but the upper passenger rear looks bent upward just outboard of the tapered area.
Discussion Starter #9
Thank you all. You guys are much more friendly than some other forums I’ve been in. I just swapped the hubs to see if maybe one was a bit looser than the other and the issue never moved sides. I never noticed the issue until I put the bumpers and 32s on. Machine only has 212 miles. I’ll give it a good look over and see if the trailing arm is twisted and pull the tire to get a good look at that radius rod. I’ll also get another wheel bearing to throw in that side to see if anything changes
Discussion Starter #10
Here are some pics of the rods. They seem straight to me, but I didn’t study them too hard.
Probably my eyes and the way the picture was taken. But, it looks to me as if the brake rotor and caliper is not setting square with the rest of the machine.
Discussion Starter #12
It has play just like it did before, feels just like a wheel bearing. I replaced them on both sides and feels just like it did before.
Was it a tight fit for the new bearing? Could the hub be worn enough?
Discussion Starter #14
It went in like it should. I was thinking maybe the hub was a bit worn is why I switched sides really quick and didn’t change a thing
Don't know. About all that is left is trailing arm or bent frame mounts.
To me from the pics it looks like your passenger side trailing arm is bent.
This very well could just be the angle of the picture. But look at the passenger side trailing arm in relation to the upper radius rod, and how much of the trailing arm you can see where the axle goes into the hub. From the picture looking down the trailing arm on the passenger side it looks like it’s rolled down versus the driver side. Is it doing this because the trailing arm is bent or is it a radius rod causing it to turn IDK? I would take the radius rods and roll them on a flat surface. And take the trailing arms off and set them on the table see how true they are.
Discussion Starter #18
I’ve narrowed it down to only two things. The wheel bearing has play in it or the bearing carrier is slightly larger than the bearing slowing for play. The wheel sits straight after you let the jack down.
Discussion Starter #19
So I finally got around to fixing the issue. I forgot they upgraded the radius rod bolts in 2018 to 12mm. Superatv sent me a bumper to except the smaller radius rod bolts, allowing play in the arduous rods. I drilled out the bumper and no more angled wheels
1 - 19 of 19 Posts
