1 - 7 of 7 Posts
This thermostat housing allows for simple installation of a water temperature gauge into an 800cc Polaris RZR! No longer do you need to drill/tap your stock thermostat housing and lose the bleed screw, nor do you need to cut into the radiator hose!
This billet aluminum (tumbled finish) assembly replaces the stock thermostat housing and contains a location for a 1/8"NPT temp sensor, the stock bleeder screw in addition to to the stock hose and clamp. This product is used in the Dakota Digital SEN-24-1 sensor package, but can be used in conjunction with any water temperature gauge/sensor which has 1/8"NPT threads.
The UTV-6175 retails for just $29.95!
On the shelf ready to ship! UTV-6175 Polaris Billet Water Temp Sensor Thermostat Housing
Discussion Starter #6
Looks good do you make it with a -12 fitting
Not 100% sure what you mean by -12 fitting. I'm assuming you mean 12mm sender? The sender port is fairly close to the wall so it doesn't restrict flow. You couldn't open it up enough to accommodate a 12mm. You'll see when I post the picture of the bottom in a little bit.
Discussion Starter #7
1 - 7 of 7 Posts
