1 - 3 of 3 Posts
We've all seen it or heard of someone doing it, adding 2 or 3 or 4 washers to their wheel studs to add just a little bit of room for tie rod clearance or to clear a sway bar or whatever. Usually its when someone just doesnt want to run 1" or wider spacers so they add a couple washers. Heck, I've done it myself, but never again!
With these "Slip On Wheel Spacers" you have a nice full flush mounting surface against both the HUB and the Wheel Mounting face for much less stress on the wheel studs and a perfectly even wheel mount.
At this point, I have 1/4" wide and 3/16" wide sets to fit 4-146, 3-137, and both the 4-110 and 4-115 are integrated into the same spacer. These are made of aluminum to keep the weight off!
1 - 3 of 3 Posts
