1 - 10 of 10 Posts
I got a new xp900 before I go out and drive it I would like to know what you guys recommend I do to the air filter.Should I buy a K&N or grease the seal ,I dont want to ruin my motor.
Just grease the filter edges and make sure the lid is installed right. You will have no problems.
i bought an airaid. and i put a little grease along the edge. sock filter and grease will be just fine. just make sure the lid is on right.
In my opinion the stock paper filter is the best air flow and fine dust filter............at least using the stock air box system
Discussion Starter · #7 ·
good Because I want to keep the engine stock so I dont have issue's with it.I just hope it's as dependable as my yamaha rhino was.
Standard Vendor
If you don't like the mess of grease, check out our Super Seal Gasket Kit. Also just introduced our new intake kit that fixes the negative pressure problem with the box and adds some punch to your stock machine.
Mark
Mark
do you have a link to those products?
The RZR-xp is the sh!t but it is not even close to Rhino quailty.:shhh:
1 - 10 of 10 Posts
