1 - 16 of 16 Posts
I wanted to try to do something to cut down on the amount of heat that comes into the bed. I tools some duct insulation and put it on the bottom of the bed. The insulation has a sticky back and I used some 3m contact spray as well. I will try it out this weekend and see how it does.
Hope it works. I have melted a cooler on the passenger side over the exhaust. I wrapped the headers but have not had an opportunity to test it yet. It doesn't matter what speeds I run, it gets damned hot.
That first photo is a little hard to understand.
I assume you took off the bed and flipped it upside down, then put it back into roughly the same spot on the RZR.
I took several photos of my 2011 RZR4 when I make my cheapo Heat Shield. Do you care if I post the photos in here?
Nightmare, that first photo is the bed upside down. You can use themis you like . Will take a few more this weekend when I run it. Will let you all know howit goes.
I know my bed can get pretty warm, but not hot enough to melt a cooler! I have a 2011 as well, I wonder why the difference. Hearing that scares me a little because I usually put a plastic gas can on that side of the bed on long rides...
I just set my can on a peice of 3/8 plywood.
If that insulation stays on that would be quiet a bit simpler than my solution but if it don't work out. here is how I solved my heat problem. I've had it on since September I've been though a lot of mud and a lot of pressure washing since then and I had it off a few days ago and it seems to be holding up quiet well
http://www.rzrforums.net/rzr-s-specific-discussion/59645-heat-problem-cargo-bed-conquered.html
BTW: don't know what type of trails you ride (high speed or more rock crawler type) I've found that if I stay in low gear it keeps the clutches engaged when your off the throttle therefore keeping the air moving and blowing out a lot of that heat Don't know for sure but I think that is part of our heat problem
Hope That Helps
I got an RV vent cover...same material and stuck it to the bottom of my cooler. It does help but it still goes to water pretty quick.
My rzr4 bed got extremely hot. Hot enough that it started melting my lock n ride cargo box. I bought the heat shield from UTV.com for $134 and it works like a charm. Problem solved.
I've got the same thing WITHOUT the logo, under $10. Works great. No more oven in the bed. Just cold beers. :beer:
Care to share yours chipper? Under $10 sounds great. Mine hasn't melted anything but it gets crazy hot. I don't like touching the bed...
I actually made this in HVAC class one day being bored. It's just thin duct work, you can pick up a small piece at lowes under $10. The X bent into it just keeps it a little stiffer. I used tin snips to shape it up a little. It did great and no heat was in my box.
Discussion Starter #16
I ran mine today and the bed was a lot cooler. I could touch the bed and it was a lot cooler that the area under the bed. I works out well for me and seem to stay on well. After a few rides we will see how it holds up.
1 - 16 of 16 Posts
