1 - 20 of 23 Posts
Billet Big Bore Cylinder with steel sleeves, available in 84, 84.5 & 85mm bore sizes for those who want a cylinder that can last the test of time.
Start @ 84 bore and have 2 bores left, no need to send into re-nikasil or re-sleeve after a mishap. Just bore it & be back on the road the next weekend.
Cylinders are available in a few different kit forms:
Kit 1 is a standard height cylinder with CP pistons & a top end gasket kit.
Kit 2 is a tall cylinder for turbo machines with a stroker crank. It comes with CP pistons, top end gasket kit, solid lifters, adjustable pushrods and a tall ARP style stud kit to hold the cylinder and the head down.
Kit 3 is a standard height cylinder with CP pistons, top end gasket kit, solid lifters, adjustable pushrods & an ARP style stud kit.​
We have also developed a great CNC port with +2 valves that works great as well.
Check out our others posts for more info.
Uh Oh
Eric is installing kit #3 on my RZR soon:popcorn:
Looks like the same barrel that Tower Works has engineered over the past year. Is this just a copy ?
Its easy to copy something ... if you dont have to do any of the R&D
Discussion Starter · #15 ·
We do have these in stock and ready to ship, as far as stud kits go these were made for the taller cylinders for the turbo kits-they are available for $199.95 per set, kit includes taller ARP style studs with flat washers and 12 pt ARP nuts, these will bolt right into your stock cases. We are working on a standard height cylinder version this should be available soon and will be the same price.
Looked on your site and could not find them ? So how much for Kit 2 ?
Just curious, what kind of head gasket do you use on your kit ?
milos
Kit 2 is $2150.00 with the stud kit. As for the gaskets we have a few different options.
Sorry I should ask, if is a copper (shim ) non compressible type or multi layer steel one with coating, which compress little bit.
milos
1 - 20 of 23 Posts
