OK everyone, I want to address an issue That has been coming up OVER & OVER & OVER again It just doesn't stop..... Some of you are aware of my "build Thread" in the projects section. But as many of you really don't get into other peoples projects and/or look for specific details of a problem/issue/solution. I am going to make a Solution Here...
I'm Talking about Snorkeling your RAZR..
I have noticed that I covered the basis for the installation of a True snorkel relatively well (in my eyes its actually VERY VERY VAGUE).. Once I am done with this, I am going to make a VERY DETAILED thread with so many more pictures, the tools, the tricks, the ideas, the proper way to seal everything, the proper way to PRESSURE check and ensure no leaks... what to do if you buy a "Kit" because I can tell you now and from experience, anyone saying that they are selling a "kit" that has everything you need is in fact a LIAR!!, do they include all the sealants, NO, special tools, NO, Proper instructions, NO, contingencies (different parts) if you are running any type of aftermarket air box, NO and the list of short comings goes on!...A $150 'Kit", will easily turn into a $300+ project...I kid you not, And the time and care to properly snorkel your ride is not even mentioned, its also not just installing the "snorkel that needs to be done" there is actually much more and can be very time consuming..Example: wiring harness, your stock wiring harness has a black type of tubing (like shrink wrap but not tight) I'm NOT talking about the wire holding tubing that "organizes wiring". It's always nice to pull your front plastic off and undo your wiring harness to find that even though you took precautions....3 month old water comes pouring out of your wiring.. They don't even cover in the instructions to pull off and seal your Clutch Cover...What is the use of snorkeling anything, if you don't even know what the hidden weak links are...Nobody wants to find out the "hard way", So I will make a genuine THREAD, that is COMPLETE from start to finish covering absolutely everything, IT WILL INCLUDE WORKS FROM OTHER MEMBERS AS WELL AS PICTURES!, I am going to cover EVERY aspect!! once it's done we will REFINE it....Then maybe we can make it a "sticky" so the whole "snorkel" issue can finally be laid to rest. People will know what parts to buy, what benefits are from kits, what the shortcomings are, prices ect....And I will even cover the 2011 ect... with pictures!!, I don't usually "double post" (this describes my intentions a lot better than I wrote near the end of my "Build" thread) but I am going to take this last part and make a thread about solving the "snorkel" issue permanently for all those who just are not into reading a thread about my build. I can have it done within 10-12 days.. Just have to bring in a 2011 from my local dealer... Its time to nip this "whole" Snorkeling /submarine issue in the butt..
for those who want an idea of what I've been up too its here:
http://www.rzrforums.net/projects-how/35774-say-goodbye-my-old-rzr-construction-has-begun.html
Any input or suggestions are welcome, I fully intend on not only using my work but combining the work of others in our Forum to Create this.."Manual" for the obsession of Snorkeling... This is also going to cover differant methods of snorkeling, not just the "basic" ones we usually see..
UPDATE: I SEE A THREAD WAS JUST STARTED ON THE 170 ABOUT SNORKELING AS WELL, I WILL ADD THAT TOO AS I HAVE MY SONS SITTING RIGHT NEXT TO MINE...
Cheers guys, Mike#9
Cheers guys, Mike#9
