New here i have recently came across a polaris razor 800 that had a motor swap, trying to verify what motor it has in it. The sticker on the side of the motor say RZRXP 925-15,T.
Thanks in advance
Thanks in advance
That’s what the number he posted means?Gas combustion type with 2 cylinders side by side.
So turbo RZR eng. fires at a different degree than non turbo Eng .Pieriod end of story! You will need wiring harness from a like model year along with a pcm for a turbo of that year . I have done this believe me.New here i have recently came across a polaris razor 800 that had a motor swap, trying to verify what motor it has in it. The sticker on the side of the motor say RZRXP 925-15,T.
Thanks in advance
Thanks a lot on the info. It does running on 1 cylinder witch is on the mag side. But how can I confirm that it’s a turbo engine and what year it is? About ready to tell him to burn it down. He doesn’t know any info on it at all.The car you see was a non turbo that i built 3 motors for using the best parts available at the time and the right clearances pistons valves couldn't keep them together and of course took out the turbo every time. $ 10,000.00 later i put a turbo eng. in its place would run on one cyld. then i found out the turbo motor fires @ 170 deg. installed turbo harness along side OE harness and installed turbo PCM . using a dynojet V tuned it never looked back. super fast as fast as my 2019 can am RS turbo with W/S 220 Hp Tune
So there is a QR code on mag side it will tell you.Thanks a lot on the info. It does running on 1 cylinder witch is on the mag side. But how can I confirm that it’s a turbo engine and what year it is? About ready to tell him to burn it down. He doesn’t know any info on it at all.
Yes it is. This is itSo there is a QR code on mag side it will tell you.
It wouldn’t scan about to try again not special scanner is needed right. I should be able to scan it like any other QR codeAnd did you scan the QR to see what happens?
