Status
Not open for further replies.
1 - 3 of 3 Posts
I took my 2011 RZR 50" in for it's first 25 hr service. I got them to change all the fluids and filters etc etc. put on 26" Zillas and got them to check the clutches and belt as it just recently started to be real sluggish down low...acceleration just seems real poor.
Well I get it back and engine light is on, no speedo or odometer and I still have my sluggish problem that they said they fixed.
Of course I am taking it back to them but do you guys have any ideas what could be causing these issues? In case I have to lead the dealer in the right direction as they seem clueless.:rm_thumbdown:
Banned
Are you at altitude? Personally I would put in a clutch spring and weight set for 27" tires and high altitude. Also, get an "S" belt and replace yours and keep the old one with you as a spare. I have an EPI clutchset in mine for just that and run 26.5" tires and do just fine running up to 12,000 feet in Colorado. BTW mine's an '08 standard.
Also sounds like a wire connection or sensor is loose/bad for the speedo stuff
1 - 3 of 3 Posts
Status
