1 - 11 of 11 Posts
2010 RZR that has Uni Filter and full Bikeman exhaust won't stay running. Just started doing it on Saturday, any suggestions?
Yes it is still under factory warranty. At the service shop and still can't figure out the problem yet.
Is the UNI clean? Has it been freshly oiled?
If so.....
It could be over oiled causing the engine to stall. Try a paper filter to rule that out. Check the plugs - specifically the color.
By the same token, if the filter is dirty and clogged.....well, I think you'd know.
Best of luck gettin 'er going again. :ride:
rzr4mud
Been in any deep water lately Jason?
Discussion Starter · #8 ·
No deep water, not over oiled, took the outer filter off and still not running right.
Just kidding!
Could there be oil on the T Bap sensor?BTW the uni filters dont work good and they make a mess. there are better options available.
Discussion Starter · #10 ·
Thanks for all of your suggestions, The mechanic called today and said something about the mapping being messed up from not getting enough airflow. Let's hope everything is all good now.
1 - 11 of 11 Posts
