My transmission had been pretty hard and getting harder throughout its life to get in and out of gear so I decided looking at the manual to take the inner detent sleeve out and see if i could get the spring and ball and see if anything was wrong. I thought since I was rebuilding the rear end anyway I wouldnt need to pull the transmission or anything since access to it is easy with rear end out. I got it almost got the screw all the way out before I ran out of room and then decided to just screw it back in and leave it be. Well after I put it back I noticed my shifter is very very easy to shift now probably too easy. I assume it probably won't stay into gear when running. I'm a little confused because the way the manual put it as long as you didn't pull the outer detent screw first it should be fine without dropping the spring in the ball I pulled the inner detent screw under that impression and now I'm thinking the ball and spring and fell in. it's 3 a.m. and I'm tired so I haven't thought about changing fluid or draining it or anything like that yet I was just curious if I'm going to have to tear into this transmission or not now for something that I probably should just left alone to start with. Any help is appreciated. Also I had the gear position sensor off when I was doing this I pulled it to see if the gears and everything was fine or if having the sensor out would make it shift easier.
