1 - 4 of 4 Posts
Ok I had the progressive springs on my 08' best investment I ever made.
Here is the dilemma:
I now have a 09' S
Stock springs sagging, preloaded to compensate.
Plan on purchasing Progressives and Pitbull tires 26.5
Will this give me the 12" GC or do I need to add the Racer Tech 2" lift as well?
I don't want to much GC, I don't want to lose my center of gravity for the kind of riding I do. Also read about revalving the shocks - is that needed more in the dunes vs mountains in Tenn?
looking for 12- 13" GC max but want a good ride. One side note I like what the Racer tech lift does with the shock angles
Input greatly appreciated...
I had 12" of GC when I switched to the progressives on my 2009 RZR-S.. and that was with 25" paddle tires sitting on concrete measuring from the concrete to the hitch.
You can get 12'' without the lift, pitbull 26.5 are the same size as bighorn 26'' (i have both) you can even bump it up to 13 by adding some preload. I have 13.75 rear on mine with the 2'' lift. The racertech 2'' lift will only give you a little over a inch rear and about a 1.5 front. A true 2'' will put your cv joints in full bind at full drop and you dont want that.
1 - 4 of 4 Posts
