My check engine light keeps coming on
70K views 38 replies 17 participants last post by  adamdoss
My check engine light comes on randomly . I've checked oil and coolant nothing seems wrong but the light comes on and goes into limp mode. I can stop and shut it off a d immediatly restart it and it goes away for sometimes an hour or more but it keeps coming back on at random times. Any ideas what could be causing this? Hopefully it wont quit on me completely . Everthing is running fine. Voltage is fine . Just get the engine light and limp mode.
I do not like to brag, and this is nothing to brag about. My first rzr was the rzr 1000. The first time I took it to the Oregon dunes was this last October. After a few days of riding I noticed the engine light coming on and off, then sometimes the gas pedal would appear to not work for a split second, Of course I thought there was something wrong with the machine.
I took it to the dealer and found out there was a "CODE" for using the gas and brake at the same time, not only a couple times but 126 times I had done this. They cleared the code and the engine light is gone. It's a very bad habit I have and I'm trying to not do it anymore.
#29 ·
I do not like to brag, and this is nothing to brag about. My first rzr was the rzr 1000. The first time I took it to the Oregon dunes was this last October. After a few days of riding I noticed the engine light coming on and off, then sometimes the gas pedal would appear to not work for a split second, Of course I thought there was something wrong with the machine. I took it to the dealer and found out there was a "CODE" for using the gas and brake at the same time, not only a couple times but 126 times I had done this. They cleared the code and the engine light is gone. It's a very bad habit I have and I'm trying to not do it anymore.
Hi, I have this problem right now, yesterday it first appeared. What did you do to fix it?
So today in about 30 miles of riding it came on 5-6 times and I most definitly did not touch the brake and gas at the samr time when it came on. Never happened at any of the same conditions. couple of times was running 30-40 MPH on a gravel road, once climbing a hill another time I was completely out of the rzr and was sitting there all alone idling . So guess I'll take it home after we ride some tomorrow and clean it up and start checking all my connections. Otherwise guess I'll have to take it in and see if the dealer can figure it out.
I've had the same problem with mine. Check Engine light comes on and no acceleration, let off gas pedal and hit it again and light goes out. I brought it to dealer and it had code stored for gas/brake use at same time. I never ride with foot on brake and gas. The dealer installed a new brake light switch but I haven't had a chance to test the fix yet.
I have never had to take an RZR (this is my 3rd rzr) in for service before. But since I buy all my parts from Mancuso South and they are the closest to me that's where I took it. Mike in parts treats me right and had several good conversations with their Manager so hope they get mine figured out quick. I've read alot of post's on the facebook pages where there are quite a few other's who are having / had the same problem. A couple they had to replace the computer to fix it. When they hooked mine up to check for codes there were several issues that came up all electrical related.
#23 ·
I've been having a similar issue, but more random then same others have mentioned above. Do for my first service in a few weeks so i'll post codes and what the dealer finds out.
RJ
