For all of you guys that ride in mud... has anyone used spray foam to seal and fill those areas that collect and pack mud. You know the areas I'm talking about, around the wheel wells, under the body panels etc. If so, how has it worked for ya? I'm not talking about spraying WD40 or Pam on the underbelly to shed the mud (doesn't work very well) or placing foam pool floaties in there either. I mean foaming the crap out of those areas with foam sealant! After a couple hrs of power washing and grabbing gobs of mud out with my hands and still not nearly getting all the mud out I'm wondering if it would work? I'm sure it has been talked about before. If someone has a real solution like this it should be a "How To" sticky (pun intended). It is a big problem with RZR owners! Once I get it out (mud) I would like to keep it out, at least keep it to a minimum. Thanks guys!
