1 - 20 of 100 Posts
craigstumph
MRT kevlar sidewall tires now available. These are the tires to run if you want to win races or just have a long lasting tire. The tires are very similar to the Pro Armor Crawlers in looks. They have tougher sidewalls and wear longer. Super sticky 32" tires are also available.
MRT “RACE” TIRE
Free Shipping in the Lower 48 States
ANTI-PUNCTURE – KEVLAR “TRIPLE BELT SIDE WALLS”
28″x 10″ – R14 | 17/32″ Tread | 32lbs | 8 Ply | 1100lb Load Rating
30″x 10″ – R14 | 17/32″ Tread | 38lbs | 8 Ply | 1330lb Load Rating
30″x 9″ – R15 | 0.75″ Tread | 32lbs | 8 Ply | 1330lb Load Rating
32″x 10″ – R15 | 16/25″ Tread | 37lbs | 8 Ply | 1390lb Load Rating
4 BELTS Tread | 3 BELTS Sidewall |4 BELTS Bead – DOT Compliant!
***NEW MRT "RACE" TIRES ADDED***
33"x 10" - R15 | 25/32" Tread | 39lbs | 8 Ply | 1390lb Load Rating - NEW
33"x 10" - R15 | 25/32" Tread | 39lbs | 8 Ply | 1390lb Load Rating - STICKY
Delivering KEVLAR TRIPLE “ARMOR BELT” NO FLATS RUN FLAT Track and Field; The Ultra Light Weight Tire will support you on the Track, Rocks, Mud, Sand or Gravel. Separated Tread Design and Aggressive side bits keep you vehicle on track 28 10 R14 and 30 9.5 R15, Only Side by Side Tire in this size. The 9.5-10” Width performs the best on Race Tracks from cornering to climbing. Racers Choice! MOTO RACE is constructed using a Special Duro Compound to provide a smooth riding experience.
MRT “RACE” TIRE
28X10 R14 MOTO RACE DOT COMPLIANT 8 17/32 32 1100 DOT/COMP
30X10 R14 MRT RACE DOT COMPLIANT NEW STOCK 3/30 8 17/32 36 1330 DOT/COMP
30X9 R15 MRT RACE DOT COMPLIANT DOUBLE KEVLAR 8 17/32 32 1330 DOT/COMP
32X10 R15 MRT RACE DOT COMPLIANT DOUBLE KEVLAR 8 17/32 39 1390 DOT/COMP
MRT “X ROX DD” – DUAL DURO
30″x 10″ – R14 | 25/32″ Tread | 38lbs | 8 Ply | 1330lb Load Rating
32″x 10″ – R14 | 25/32″ Tread | 42lbs | 8 Ply | 1430lb Load Rating
Delivering KEVLAR TRIPLE “ARMOR BELT” NO FLATS DOT COMPLIANT Rugged 8 Ply, 1330lb Load Rating The CRAWLER “X ROX DD” Features special sticky compound Tested Best in Class you can run at 5PSI all day and finish the toughest courses with the checker flag.
https://www.proutvparts.com/collections/mrt-tires
skull2002
I have the x Rox dd. in 30". . over 1200 miles on them so far,,with 800 from Taylor park Colorado, ( two 400 mile rides ). hands down the best tire I've ever bought ! and with 8 four wheelers, and 4 rzr 's under my belt I've owned a lot of different tires.
Have RZR...will travel
Did a lot of research prior to getting new tires. I ride about 4000 miles or more a year in the high desert, washes and rough rocky trails. Require excellent traction on a variety of surfaces, reliability and durability against punctures and long wear. Decided on MRT 'Race' 32x10x15 and got the best price available from Craig at PRO UTV Parts!!!
These tires are phenomenal!!! True to size and only 36.5 lbs! That is 7.5 lbs lighter that the Tensor Regulators they replaced. I loved the Regulators and got 3,600 miles out of them with NO flats or punctures, still had 5/32" tread left. Believe I will not have to use the replacement guarantee for a sidewall puncture even if I utilize the runflat feature and expect to get 5,000 miles on the MRTs.
Yes they are expensive BUT when you figures in the mileage they cost less per mile than most any highly rated tire. Can't go wrong with these tires especially at PRO UTV Parts price!
I'm still probably a couple months out and leaning towards Roctane again but shoot me a price for (5) 32-10-14 to 75457. It would be nice to move up to 32 and not gain any weight...and possibly have a tire as tough as my Roctane
craigstumph
Discussion Starter #15
craigstumph
Discussion Starter #17
I'm still probably a couple months out and leaning towards Roctane again but shoot me a price for (5) 32-10-14. It would be nice to move up to 32 and not gain any weight...and possibly have a tire as tough as my Roctane
The UTV "Race" tire does not come in 32x14 only 32x15. The XROX DD does, but it is heavier.
42 lbs. Same as my 30" Roctane, right?
The Roctanes are 42 lbs. Will the XROX DD work for you?
Possibly, I love the idea of being able to go up to a 32" tire and not be any heavier, and these are supposed to be tough also. That's one of the things that I like about my Roctanes, they are TOUGH. However, moving up to 32" Roctane is 11 lbs heavier PER TIRE. That in itself has me looking at other options
1 - 20 of 100 Posts
