Kustom, thanks for the help on this...
Troybuilt, you have some issues for sure.... the lift and tires will kill mileage there is no way around it...
Ways to improve it ( and I see you have done some of this already...)
tire psi at proper levels,
Air filter maintanance.... do you have a high flow intake yet...?
exhaust As stated though it won't improve it leaps and bounds but will help keep exhaust temps down.
fuel filter maintanance... at 26,000 have you done one yet?
Is the speedo calibrated for your tires?!?!?!?!?!?
light foot on go pedal.
Please keep in mind also that, running boards will also add to the fuel mileage problem...
more wind drag and resistance going down the road..
I do not do running boards everyday, but if that is what you want I am sure I can get them...
Let me know if there is anything else I can do for you..
If need be please call us, or pm me for any other answers to your questions.
Thanks
Diesel6.7, I appreciate the help, its probably hopeless.:sad:
Yea, I've had the speedo recalibrated at the dealer, its close but not quite right. I have figured its off by 7%, and figured that into the mileage calculations. I need to get a better programmer for sure to calibrate for the 35" tires.
Speaking of which do you prefer one programmer over the other? Banks, Edge, Bullydog, etc... How will the tranny hold up with the extra power? I went thru 2 autos in my '02 Dodge and it was bone stock. Which exhaust should I get? I don't want anything too loud.
No, I don't have a high flow intake.
I had the dealer change the fuel filter at 10k-ish so it has been awhile. I'll try and do that this weekend. Is there 2 of them on this truck or something, or just one?
