1 - 7 of 7 Posts
i have a 900 on ol2's but in the front end it is making a squeeking noise that is driving me crazy. i have greased every grease point and i still cant find it. has anybody else had this problem if so what did you do to fix it
Probably the shocks, take them off and tale the balls out of the end ( where the bolt goes through) clean them, grease them and put back together. Everyone that owns one has had to do this to help with the squeaking.
I had a squeak noise coming from mine, thought it was the shocks checked all them it wasn't. So i pulled the center consol off to check the drive line and found the slip yoke in the center of the machine was never greased from the factory put some grease in it and my squeak was gone.
Discussion Starter #7
ok cool well im going to take it all apart and just go to town with the grease then
any other tips that might be help full ?
thank you all for info
1 - 7 of 7 Posts
