1 - 8 of 8 Posts
· Registered
Family went to Little Sahar (Oklahoma) this weekend and wow what a awesome time. Why did I wait so long to get one of these toys. Been there main times before but on quads and get beat to death. This RZR-S is awesome love the ride. Only 2 bad things I noticed was 1. regular lights at night are not that good, 2. turning in sand sometimes did'nt work all that well. Seemed to push a little then grab no biggy. Dropped air down to 5 psi in front tires not much of a change. Someday will have paddles on the rear and smoothes on the front. Guys this thing is a riot though.
· Registered
Dale....Sounds like you had a good time. A blast they are! Far superior to ATVs without question.
As far as you light goes, make sure the lights are adjusted down and not sticking up in the air as mine were from the factory. There's two small phillips head screws to adjust the beam height. That might help if you haven't made the change already.
· Registered
Get yourself some HIDS, that'll help a ton in the sand at night. On your bighorns, air them down to 4lbs and run it in all wheel drive, you'll notice a big difference.
Jason
· Registered
Discussion Starter · #4 ·
Thanks for the tips guys When we go up there again I will check the light height and air the tires down to 4psi. I did run it in all wheel drive just seemed at times it would push then catch no to big of a deal. And I also saw alot of guys running the HID's might look into those as well. Thanks again.
· Registered
I noticed that on my rzr 4 need to do that.
· Registered
My head lamps and all the ones I have checked on the 10s have all been all the way up. I think its the same guy at Polaris that puts all the steering wheels on crooked also. It is a torqs bit to adj. the lights on the 10s.
· Registered
My buddy got HIDs and we could tell a huge differenece when we ran at Little Sahara last May. We plan on going back soon.
If your looking for Paddles stop by Stewarts Buggies. They have them in stock and you can drive your rzr to their shop. I bought some for my s and it helped a lot and the price was good. Bought new rims with the tires mounted so now we just switch them out.
Glad you liked your Rzr!
1 - 8 of 8 Posts
