Just used 3/8 hitch pins from Tractor Supply. Drilled a hole in the bracket that holds the bed also. When I disconnect the sway bar, the pins hold the ends up out of the way.
Didn't want to remove it totally. I do like to go fast sometimes, but lots of my time will be spent in rocks, so I want the articulation.
Used my little trailer as a RTI ramp of sorts.
Before. This was as far as it could go up the trailer before it lifted a tire.
After. It ran up to top of the trailer. Had more it could go but I ran out of ramp.
Rear before
Rear after
Rear before
Rear after
