Sure. What year and model?Any options for an XPT transmission gear reduction?
The only one that absolutely will not affect your high range is the 21% Low range only reduction. With the 33% Low range kits, you have an option of 12% reduced or 2% faster High range. Reverse will be reduced by 12% with either option. If you have any plans for larger than stock tires then I would recommend the 12% reduction in high, Even with just 30" tires you will have plenty of speed and keep some of the quick response that you have with the stock tires. Don't come with instructions, the general write up earlier in this thread is all I have done to date, there are some video's on you tube.Very interested in your setup - leaning towards the 33% reduction. My machine is 2017 xp1k, and in the few months of owning am missing a good low range. Any new options? Don't want to effect my high range, still love me some speed once and awhile lol. Your setups come with any instructions? sorry if I missed some of this in the thread.
Now I want some popcorn...very interested:bigpop:
The 21% Low range only kit is the only one that does not affect High. PM on the way for prices.How much for the kit that reduces low by 47% and reduces high and reverse by 14%?
And, is it possible to do a kit that only reduces low? Price?
2017 XP 1000
OK. I didn't realize that. Thanks for the info. The lower only reduction does sound perfect for me though. I go between the glamis and and mountain and the rubicon. I would love the reduction for rubicon but keeping my high range for the dunes. I will keep your kit in mind if I decide to upgrade my secondary. Maybe when I decide to replace my transmission bearings.I would love to but that is not an option on 14-15 models. 14-15 models only have Reverse shaft option available, (12 or 26%). That will lower all three ranges. However, If you can source a '16 or later secondary in good shape, (I can price you a new one or if you are more of a crawler, Duraclutch), and possibly re-calibrate your primary then I can put together a kit that will let you retain some of your High range speed while reducing Low range and Reverse. If any of this interests you let me know and I'll shoot you a price
Whats the model of the input shaft you sold me? Have a misalignment issue (to say the least)I would love to but that is not an option on 14-15 models. 14-15 models only have Reverse shaft option available, (12 or 26%). That will lower all three ranges. However, If you can source a '16 or later secondary in good shape, (I can price you a new one or if you are more of a crawler, Duraclutch), and possibly re-calibrate your primary then I can put together a kit that will let you retain some of your High range speed while reducing Low range and Reverse. If any of this interests you let me know and I'll shoot you a price
I just did this conversion. 12% reduction in high, 26% in low and reverse.
Upgraded my 14 to a 16 secondary shaft and reverse chain.
Did it over a few days. kind of intimidating, but if you stare at it long enough it makes sense.
took about 6 hours total after the trans was out.
Carl was very helpful over the phone with tricks and experience.
EDIT: Also to note these were all top quality pieces. I rented (free) a bearing puller from NAPA and used two PVC short pieces and a block of wood as a press.
One or two of the bearings needs that pitchfork splitter tool, or some other creativity to get off, as you cant get the jaws under them.
Everything went back together, no misalignment, worked like stock. It will be a few months before I can run it since im doing a motor swap. Plan is to run 32" tires and have a trail/crawler desert rig with occasional dune trips
I would like to buy one of those kits. Any contact info?I have put together low range only gear reduction and been installing here locally. 21% reduction in low range only, works wonderful with 30" tires while crawling. Is a big improvement with 32's. We are working on another setup, 33% reduction in Low, 12% reduction for Reverse, High range stays stock ratio. Should work great for 32" and larger tires. I will have the first 33% set installed next week for trial. If there is enough interest on here I will sell them as a kit for you to install.
What machine and what gear reduction are you looking for? All gear reductions can be done with OEM gears.I would like to buy one of those kits. Any contact info?
