1 - 11 of 11 Posts
I'd like a little extra ground clearance. I have a 2010 RZR with a dual exhaust setup. I have 26" Grim Reaper Tires on a ITP rim. I believe it also has 1.5" wheel spacers on all 4 corners. Any input would be appreciated. I'm looking for something of good quality and simple to install, without breaking the bank. Thanks!
I just installed a CATVOS lift and I like it because of the ease of installation. It took me less than 30 minutes to do the front and back.
I use the emp 2 inch lift on my rzr 4 it did the job for me. It is very strong and was not that difficult to install. The only thing that I am not sure about is the change on the shock angle. This would it seems to me reduce the overall travel of the fox shocks.
Any pics, or change in ground clearance numbers with your set ups?
If you do a search on here for CATVOS you will find allot of info. I put some pictures of mine after the install, the whole rzr and some close ups of the lift. I was at 11 3/4" in the rear before the lift and 15" in the rear after. The CATVOS lift is adjustable from 2" to 3" and I went with it because I run 29.5 Outlaws and 27.5 Growlers and I can adjust the height for the tires I'm running.
Don`t go over 2 inches or you will break stock axles frequently.....
Ok, this with all lifts ?What if you use shocks straps so the arm dosent over swing? From what I have read over time its normally the drivers side rear that has the problems ?Is this gust with stock axles ? I think some of the lift kits change the angle of the shocks is this for better or worst ?Thank for any info.
I understand that with some lift kits you have to drills holes in the frame. Is this in the square tubing? Does this weaken the frame??? What do you all think??
1 - 11 of 11 Posts
