1 - 14 of 14 Posts
Does any one know what years
Polaris Ranger RZR Black Bed Rail Extender - 2877316-458 fits?
Or where can I find this out?
I saw a used one on ebay and the description said it fit a 2008 - 2010. Had a picture of it on a 800.
If you are asking about the OEM bed extenders once offered by Polaris you might get some info going to “search community” here.
I think they where discontinued in 2010 or 2011. I had a 2012 800s and couldn’t find one. I ended up making my own from PVC and painting to match.
Best of Luck
Forgot to add the OD of the pvc is a tad larger than the stake holes on the bed. I used a belt sander to reduce the diameter some on the uprights where they go into the bed.
3/4 PVC plastic pipe would be the best fit.
Thanks for the help CA! I couldn’t remember for sure, slept a couple times since then;) Again, l can’t remember for sure, but l think there was a thick wall and a thin wall, be sure and use thick wall.
I couldn’t believe how stout it was after getting it installed!
If you use the electrical (grey) PVC it will be thick wall.
1 - 14 of 14 Posts
