1 - 20 of 25 Posts
craigstumph
POLARIS RZR 1000/TURBO/TURBO S/RS1 HIGH CLEARANCE RADIUS RODS BY LM UTV
Fits 2014+ Models
Straight or high clearance available
High Clearance kits include:
2 fixed length high clearance lower arms with 5/8 spherical bearings
2 adjustable upper rods with RH/LH 5/8 Heims
17-4 Stainless Steel spacers designed to keep the lower arm upright
3 Piece Chromolly PTFE lined 5/8 bearings
6061 Aircraft grade aluminum
Designed and Manufactured in-house, in the USA
This kit does not fit with an OEM rear bumper
Lifetime warranty
Straight Kits include:
4 masive 1.5" X 1" 6061 adjustable radius rods with RH/LH 5/8 bearings
Machined from every side
Easily adjustable on the vehicle
Lifetime warranty
PM or order online:
https://www.proutvparts.com/search?type=product&q=lm+UTV
What can you use if you have the OEM Polaris Rear bumper. Are there not any high clearance ones that will fit with Polaris bumper
if anyone is considering these radius rods. I can testify to their quality. I have run them for a full year now. and they are holding up great . they still look new. anodizing holds up great. and super quality bearings/ rod ends .
Do you have the straight or the arched? Do you have any problem with squeaking from the heim joint. I dont know the quality of the joint, and have been very unhappy with other manufacturers heims. Yes they all wear out, but my last rods heims where unbearably loud after maybe 50 miles
I have the arched arms . no squeaking issues so far, I think the ptfe liners eliminate the dirt front getting to the bearing surface. . I have about 1200 miles on them . I did use some large dia. rubber washers I found at the hardware store on the sides of the rods ends of the inboard end the lower radius rods to help them not rotate front to back.
1 - 20 of 25 Posts
