1 - 1 of 1 Posts
We are now selling Light for your ATV, RUV, Trailer, Truck, whatever!!!
If you see something you like, get in touch with us and we will get you a price with the shipping. We personally checked these lights out, they are impressive to say the least, AND priced much lower than the big name lights on the market, with more Lumens per light!!!
First off is the Single Row LED's,
SR Series LED Light Bar
SR-1030 10"
Single Row LED Light Bars
Specifications
Input Voltage: 9-32V DC
Color Temperature: 6000-6500K
Beam Pattern: Spot Beam(30°)
Housing Material: Die-cast Aluminum Lens Material:
PC Mounting Bracket: Zinc Alloy Electrically
Protected against RFI/EMC interference:
No radio noise at all!
10 Inch SR 5W CREE LED 2400lm
Great Style, Power and Performance this super light and compact LED Light Bar fits perfect almost anywhere.
$149 plus shipping
20 Inch SR 5W CREE LED 4800lm
$249 plus shipping
30 Inch SR 5W CREE LED 7200lm
$339 plus shipping
40 Inch SR 5W CREE LED 9600lm
$429 plus shipping
Wiring Harness
Universal Harness
Comes with on/off switch, relay, inline fuse, positive/negative
battery terminal connector for easy and fast installation
$40 plus shipping
Double Row LED's
Double Row of 3W CREE LED'S More Lumens then our Competitors.
Specifications
Power Consumption: 72W(3W*24pcs High Intensity CREE LEDs)
Color Temperature: 6000K
Beam Pattern: Spot, Flood Combo
Beam Angle: 90°/8°
Die-cast Aluminum Housing
Housing Color: Black, White
Unbreakable Polycarbonate Lens
Mounting Bracket: Die-cast Aluminum
Electronics: Integrated-Epoxy Encapsulated
Operating Temperature: -40˚C to +60˚C
IP65 Certified
Over/under Voltage protection
6" CD Series CREE LED 2880 Lumens
RACER'S CHOICE More Power at half the price of our number one Competitor. Double Row of 3W CREE LED'S More Lumens then our Competitors. Our number ONE Competitor only has 2370 Lumens.
$169 plus shipping
12"CD Series CREE LED 5760 Lumens
RACER'S CHOICE More Power at half the price of our number one Competitor. Double Row of CREE LED'S More Lumens then our Competitors. Our number ONE Competitor 11.38" only has 3950 Lumens.
$289 plus shipping
20" CD Series CREE LED 9200 Lumens
RACER'S CHOICE More Power at half the price of our number one Competitor. Double Row of CREE LED'S More Lumens then our Competitors. Our number ONE Competitor only has 7900 Lumens.
$399 plus shipping
30" CD Series CREE LED 14400 Lumens
RACER'S CHOICE More Power at half the price of our number one Competitor. Double Row of CREE LED'S More Lumens then our Competitors. Our number ONE Competitor only has 11800 Lumens.
$599 plus shipping
40" CD Series CREE LED 19200 Lumens
RACER'S CHOICE More Power at half the price of our number one Competitor. Double Row of CREE LED'S More Lumens then our Competitors. Our number ONE Competitor only has 15800 Lumens.
$699 plus shipping
50" CD Series CREE LED 23040 Lumens
RACER'S CHOICE AVAILABLE 2/15/13 More Power at half the price of our number one Competitor. Double Row of CREE LED'S More Lumens then our Competitors. Our number ONE Competitor only has 19700 Lumens.
$829 plus shipping
High Performance LED Light Bar
Z Series CREE LED's
Specifications (IP68)
Using CREE LED 10W Each
Lightweight aluminum alloy body, ultra-thin and slender, flexible in length
Innovative design - Extruded and machined flared heat sink for superior heat dissipation
2-way installation - mount by transversely adjustable stand bracket or side bracket
Waterproof: Detach connector for all-weather application
IP Rate68 - signifies dust-proof and water submersible up to 1 meter
Color Temperature: 6000K to maintain a pure white light
Beam Pattern: Spot or Flood
The Z Series High Performance Light Bar is the 2nd generation series combine superb appearance, ultra-performance, and super-low power consumption to make the light the best choice for serious off-road enthusiasts. Equipped with high power 10W CREE LED chips that produce 900 Lumens each (equivalent to 100W halogen).
4" Z Series CREE LED 1800lm
Max Power and Performance. With less amp draw ideal for side-by-side, motorcycles and high performance vehicles.
$129 plus shipping
8" Z Series CREE LED 3600lm
$219 plus shipping
Light Bar
12" Z Series CREE LED 5400lm
$299 plus shipping
20" Z Series CREE LED 10800lm
$569 plus shipping
30" Z Series CREE LED 16200lm
$819 plus shipping
40" Z Series CREE LED 21600lm
$999 plus shipping
LED Driving and Working Lights
1.5" Round High Performance
LED Single Light 1.5" |.65A|10W|900lm
$69 plus shipping
6"x2"Sleek Rectangle LED Spot Light
Sleek Rectangle Spot Light 6X2" 6.25" x 1.75" | 1.4A | 18W | 1080lm
Square LED Flood Light 6.5 X 3.5"
6.5" | 3.27A | 45W | 3150lm
$75 plus shipping
3" Square Spot Light
Square LED Light 3" 3" |1.34A|16W|1280lm
$79 plus shipping
6.5x3.5 Rectangle LED Flood Light
Square LED Flood Light 6.5 X 3.5" 6.5" | 3.27A | 45W | 3150lm
$109 plus shipping
1 - 1 of 1 Posts
