1 - 8 of 8 Posts
· Registered
I was trying to find some lights to mount on the little RZR as my son rides around the ranch with me and needed some lighting.
I ended up getting the Rigid Edge 10" LED light bar. Works perfectly and a very simple install. Mounted it the front brush bar by welding on two tabs for the stock light bar mounts. Used the supplied switch and mounted directly to the battery.
The lighting from this is AWESOME.
Specs
3.17 Amps
38.04 watts
3200 Lumens
· Registered
I do not have the greatest of night pictures, but these lights will definitely not disappoint you.
Here is a picture of him driving along the ranch road at almost a quarter mile away.
Here is direct oncoming shot at about 120ft away, you cannot even see the standard headlights the LED's are so bright. (You will see to the left some lights, that is a small ATV that has the same lights almost as the stock ones on the RZR170.)
Here is a shot before I adjusted the beams to illuminate more out as they were just shining closer in front.
There was absolutely no problem illuminating anything in front while driving. There are 20 LED's and some are flood and others beam, so you get a really good field of illumination. I would not even go bigger than the 10" as it works that well.
1 - 8 of 8 Posts
