1 - 20 of 20 Posts
· Registered
Hello, all. I have a question about mounting a light bar at the top of my windshield. I have a 2018 Polaris xP 4 1000cc UTV that has the SuperATV glass windshield, and a used 2-piece Kemimoto plastic roof. There must have been a light bar installed previously because the two indented areas have holes in them, but the standard brackets won't fit. The only other post on this forum that has a similar setup as mine, is really old, and the link to the brackets does not work anymore. Any help on any specific brackets that can go on that roof, or under it would be helpful. I know they make brackets that utilize the two bolts that hold the small roof piece in place, but I am not sure they will fit with the windshield that I have.
Here are some pics of what I am dealing with.
Vehicle Car Motor vehicle Hood Automotive tire
Automotive tire Motor vehicle Automotive lighting Hood Vehicle
Wheel Automotive tire Hood Train Motor vehicle
Automotive parking light Automotive tire Motor vehicle Hood Automotive lighting
· Registered
You need these. Get on Amazon and search "RZR XP light bar mounts" and look at the different ones.
Dasen Upper Roof Brackets Roll Bar Cage Mount for 32” Straight/Curved LED Light Bar Compatible with Polaris RZR 900 1000 Amazon.com
· Registered
Thanks for replying and reinforcing my hunch on these. I should have added in that I did see these and was thinking they were the best option for my setup, but I was curious if they’d hit or rub against the windshield.
I suppose I could order them and find out!
· Registered
At that price and with free returns if you have prime, you have absolutely nothing to lose.
I don't have the glass windshield, but with looking at where they mount on your RZR in correlation to where the windshield looks to be, looks like they will work great.
Seizmik makes some also which are more pricey and one other company also, maybe rough country or something. One of the vendors shared the 2nd option I just mentioned, they were like $150 or something crazy.
I and @Turbo_ryan use the Amazon mounts with great results. I've beat mine silly, they've been bent and banged off of trees and rock walls multiple times.
I can dig deeper into my account and share the exact ones I have but they are all pretty much the same in that style.
· Registered
That’s awesome info, I greatly appreciate it. I’ll order on Amazon as they are already in my “RZR” list. :)
Thanks again and I’ll be sure to report back once I go to install them.
· Registered
Discussion Starter · #11 ·
Success!! The brackets fit! Just ordered a 32" light bar, and will be finishing up the project this weekend. Thanks for the help, guys!
· Registered
I have the same setup as the OP, and I bought the Dasen mounts to go with the light bar. The problem is that there isn't enough room behind the light bar to be able to keep the wiper. I am still looking for a mount that sets the light bar a little further out from the glass.
· Premium Member
Bromigo. I may have what you need....
  • Like
Reactions: LinkedXJ
· Registered
Discussion Starter · #15 ·
I ordered the same brackets
I think those are the same brackets that @firedog86 has, which is what was suggested above. They look the same but I could be wrong.
· Registered
Discussion Starter · #16 ·
Here's the light bar that I ordered to go onto those brackets (https://www.amazon.com/dp/B07MCNYXFT?psc=1&ref=ppx_yo2ov_dt_b_product_details) as it should be shallow enough to fit with my wiper. I am installing it on Saturday. I can let you know how it goes.
· Registered
Discussion Starter · #18 ·
I ended up with this light bar - https://a.co/d/3fSaCTZ - and it fits PERFECTLY with those mounts, and my wiper has plenty of room. The light bar is super bright, also!
· Registered
Discussion Starter · #19 ·
Everything worked perfectly, thanks to you and @Turbo_ryan for the advice!
1 - 20 of 20 Posts
