Hi all - I have a 2 post lift in my shop. Wondering if the lift points I've picked are reasonable. Sure appreciate any advice you can give! I'm using the diagonal frame bar that goes from the central front to the side frame - the parts catalog calls is the WELD-MAINFRAME,FRT,SWAY for my front lift point. I'm lifting in the rear on the trailing arm. I've attached some pictures. Thanks for any advice you can send my way!
