Added new tire and wheel combo 27" tires with 14" rims so now there are times that the big DOT tire rub the plastic wheel well in turns with bumps, it barely comes in contact with the body, but still it a concern. Thinking of adding a 2" lift kit to hopefully take care of this problem. My question is has anybody had similar problems with big tires contacting the body and whether the lift is worth the cost. Also I run a lot of tight 50" trails in Michigan, will this lift kit only lift and not widen the wheels? Any thoughts here would be appreciated.
