At around 1000 miles my front diff seals on both sides starting leaking badly. The dealer replaced both seals under warranty. About 65 miles later both seals started leaking again. I took it back in to the dealer and they are going to fix the issue under warranty. Has anyone else ran into this problem, and what did the dealer do for you? I've read about some problems with bad machining tolerances of the front diff possibly being the issue. Has anyone else had success with the dealer replacing the entire diff under warranty?
