1 - 20 of 43 Posts
craigstumph
Direct bolt on and adjustable are available from L&W Fab.
Check out the link. PM or order online:
Small Bolt 10mm are used for Models 2014 to mid 2017
Big Bolt 12mm began being used in mid 2017
If your year model fall in the mid 2017 range, you can determine your bolt size by the socket size. If the socket is 15mm, then you will need a 10mm bolt. If it is a 18mm, then you will need the 12mm bolt.
Made from 6061 Aluminum.
645248
craigstumph
Discussion Starter · #20 ·
1 - 20 of 43 Posts
