Knock-level Power Vision 3
2.8K views 2 replies 3 participants last post by  yamahaSHO
Have an 2019 Turbo! Anyone knows the scale of knock-level on a Power Vision 3? Peak`d 1,37 at WOT! How much is bad?
Reference Ign Timing Correction Knock & Knock0. If the ECU isn't pulling timing, it hasn't determined knock. In that case, what you'd be seeing, is engine noise.
Knock control will be enabled above load:
Here is the threshold of where knock/noise will be recognized per cylinder:
When those thresholds are met, here is how much timing will start being pulled:
If your tables are the same as this 2021 XPT map, you would not be recognizing the noise as knock.
