Key on power wire?
1 reading
17K views 8 replies 7 participants last post by  crazybanshee
Im getting ready to wire up some LED rocker switches and Im looking for keyed power wire for the lower LED in the switches. I could wire them into the in cab LED wire but would rather not.
Is there an accessory wire in these new 900's like there is in my 900xp?
I found my answer. Ive read all over the interwebs that the bus bar under the hood has no power from the factory and you need to run a power and ground wire to it to make it work so I never tested it. I just tested mine and it has an orange w/ white trace wire attached to ACC and it is a keyed power.
Good deal, I was about ready to ask this question as I need keyed power for my winch and wireless control box also. I checked this lug earlier and after I turned key off it still had power so I figured that it wasn't a good one to use. I just went out and checked it and waited and heard a relay click and the voltage was gone.
Great forum, don't even have to ask, just think about it and someone else does it for you. :ride:
I used the ACC wire to operate a relay that is rated for 30A. That way you do not overload that circuit.
